western Posted April 9, 2018 Share Posted April 9, 2018 39 minutes ago, Sean. said: I've got this one, which I am looking at using. Lights full and dip are working, which is why I am confused. Didn't check the horn while the fuse was working. I don't have front fog lights it seems, only the back read one which is working. http://www.land-rover-lightweight.co.uk/Images/Wiring Diagram New.jpg no good for a 110 & 200tdi. try these instead http://www.landroverweb.com/Pdf-files/Manuals/Defender-90-110-workshop-manual-5.pdf use the 4 cylinder diesel diagram, the wire colours did not change. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted April 9, 2018 Share Posted April 9, 2018 (edited) doesn't plain purple run to the rear crossmember for the towing socket/rear wiper/interior light also, think it connects on multiplug by the clutch housing. Could be disconnected fairly easily. Pete Edited April 9, 2018 by pete3000 Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 9, 2018 Author Share Posted April 9, 2018 The items seem to match the fuses, if I take out the top right fuse number 10, the left full beam goes out. From cross checking, so far, they seem to match colour wise. Any updated ones of course would be appreciated. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted April 9, 2018 Share Posted April 9, 2018 Yep just saying the purple and brown which are generally perm live even when ign is off, power clock interior lights etc, but the longest puple one runs through chassis to rear crossmember to power towing socket and rear interior light and possibly the rear wiper to park pos? worth unplugging to test? Pete Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 9, 2018 Author Share Posted April 9, 2018 It does not have a rear light or wiper connected. I will look at the tow bar socket and see if I can disconnect that then. Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 9, 2018 Author Share Posted April 9, 2018 (edited) I do have a new trailer board tow bar, would that be of use in testing in anyway? Edited April 9, 2018 by Sean. Quote Link to comment Share on other sites More sharing options...
Powerslave Posted April 9, 2018 Share Posted April 9, 2018 I came back to the thread about to ask if you had a tow bar connector which had perhaps been crushed or similar as I was wondering if one of the purple wires was running to a dead short along the chassis. When you say you have a new tow bar - do you mean you have a new one just installed? Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 9, 2018 Author Share Posted April 9, 2018 A trailer board so that I can fix that on to the back of a trailer, and then plug the trailer board in to the port on the back of the car. Quote Link to comment Share on other sites More sharing options...
Powerslave Posted April 9, 2018 Share Posted April 9, 2018 Am I correct in thinking that fuse 1 blows immediately as soon as you put it in the holder even with all the other fuses and relays disconnected and the ignition switch off? If so, and you plug all the other fuses and relays back in, are we also saying that the only items which don't then work are the internal light and the horn? Further to that, could you locate the connector that Pete3000 mentions? Definitely unplug it and see if your lamp tester still lights up on fuse 1. Then let us know. Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 9, 2018 Author Share Posted April 9, 2018 Yes, that's the situation or test case. The internal light has never worked since I've had it. I've been trying to get that fixed as well I'm going to unplug the connector in the morning, when the rain stops! I will then post back. Thank you everyone for your help so far. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted April 10, 2018 Share Posted April 10, 2018 regardless of whether you have any or none of the accessories the purple wire will still be there (so you can add them later on) on mine it is in the panel behind the offside rear lighting panel (at the back of the indicator and brake lights) i.e I still have a thick brown and green? (for the rear heated screen i don't have) :-) The internal light is probably related to the purple wire as it uses the purple as permanent feed then to the bulb, it switches on by grounding the other side of the the bulb through a purple/blue or prurple black wire. there are three or four setups like this on the defender. in the front seat area, rear seats load area, and under the bonnet for a work lamp. HTH Pete Quote Link to comment Share on other sites More sharing options...
timc1967 Posted April 10, 2018 Share Posted April 10, 2018 I have the haynes manual for this - is it permitted to share a scan of the wiring diagram from it? Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2018 Share Posted April 10, 2018 20 hours ago, pete3000 said: doesn't plain purple run to the rear crossmember for the towing socket/rear wiper/interior light also, think it connects on multiplug by the clutch housing. Could be disconnected fairly easily. Pete Yes it does, should appear in right rear corner behind the cover panel for the rear lights. check the loom for damage where it comes out of the chassis, it might be shorting out on chassis & blowing the fuse. Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2018 Share Posted April 10, 2018 8 hours ago, timc1967 said: I have the haynes manual for this - is it permitted to share a scan of the wiring diagram from it? Yep, go ahead. Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 10, 2018 Author Share Posted April 10, 2018 After pulling down the headlining, the interior lamp was connected to nothing... Just the correct wire. Oh well, LED one to be installed now I guess. Issue found, when I unplugged the trail board / tow bar power the connectiosn seemed to have some browning. Looks like an electrical short has happened. No explaination as to why. I will go over the cable and see where it is. Timc - which book do you have? I've got the Haynes Restoration Manual by Lindsay Porter. I can't find a circuit diagram in this one. Red with a yellow tracer - need to check what this one does Small red - need to check what this one does Purple - PITA Green with a white tracer - this is for the offside e.g. drivers side back indicator Quote Link to comment Share on other sites More sharing options...
pete3000 Posted April 10, 2018 Share Posted April 10, 2018 red/yellow is fog light, appears both sides of the rear light cluster. green/white and green/red are the lhs and rhs indicators. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 10, 2018 Share Posted April 10, 2018 To see a circuit diagram just use Google. I’m on my phone but with just a few clicks I found one in “images” for a 1989 110 2.5TD. Quote Link to comment Share on other sites More sharing options...
timc1967 Posted April 11, 2018 Share Posted April 11, 2018 (edited) Edited April 11, 2018 by timc1967 Quote Link to comment Share on other sites More sharing options...
timc1967 Posted April 11, 2018 Share Posted April 11, 2018 Unfortunately, the image was 3MB on my PC is now 130KB when I re-download it from this site, so I think its lacking resolution. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 11, 2018 Share Posted April 11, 2018 For some reason this won't embed from my site Hopefully you can click to embiggen them. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 11, 2018 Share Posted April 11, 2018 I have a suspicion that one of the items on that circuit may be wired backwards, ie live feed connected to the negative terminal,and so is earthing through the unit straight to the body. Try removing the wires from the internal light first, given that it has never worked and as such is a prime suspect. If that doesn't make any difference, try disconnecting the horn and work systematically. It could be a chafed wire, but this is an easier thing to check first. If that doesn't work, then you could try cutting each wire from the fuse in turn - it's easy enough to solder them back together afterwards with some heat shrink insulation for neatness. At least you can identify and isolate the bad circuit, having everything else operative while you get around to replacing the wire that is shorting out. Quote Link to comment Share on other sites More sharing options...
Sean. Posted April 12, 2018 Author Share Posted April 12, 2018 Hi TimC1967, Thank you for those. FridgeFreezer where did you get the first one from, as that's very helpful, seeing what connects and where the wires actually go to. Snagger, The internal light was a red herring, as the wire was not even connected to anything after I pulled down the head lining I found that out. I've connected the horn and it works as expected. There is a wire from one of the plus in the engine bay that seems to have caused this. I've connected a couple so far, I need to get some more wire to jumper them. Once I know, I can either clip it, when I know what it does or get a new loom if it can't be found easily to repair. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 13, 2018 Share Posted April 13, 2018 A disconnected internal light wire could be the problem - the wire is live to the lamp, the switches being on the earth side. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 13, 2018 Share Posted April 13, 2018 14 hours ago, Sean. said: FridgeFreezer where did you get the first one from, as that's very helpful, seeing what connects and where the wires actually go to. It's from the Haynes Book Of Lies, I am sad enough to have that sort of thing kicking around on my web server. Quote Link to comment Share on other sites More sharing options...
