kevin50 Posted April 12, 2018 Share Posted April 12, 2018 (edited) OK Finally started my rebuild, but I have my first Major problem. My chassis needs new rear crossmember which I have, now most people say that to line it up properly some of the rear body parts have to be built back up on the chassis, problem I have is I bought the project with bare chassis only engine and box fitted on it but I have removed everything now ready for welding and then sandblasted. Some have suggested making some kind of jig that can be tack welded on to chassis to get new one lined up correctly. Anyone have any Ideas as I really don't want to go through the process of building back up just to dismantle straight away again ??? Thanks Kevin Edited April 12, 2018 by kevin50 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 12, 2018 Share Posted April 12, 2018 Bolt some steel through the holes in the rear cross member, then weld pieces of angle to it and what will remain of the chassis, make it strong. Then cut it off, unbolt, and bolt in new piece, weld up Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 13, 2018 Share Posted April 13, 2018 I'd just use two lengths of box section clamped to the tub floor support brackets with a drop tacked on to the ends of the box tubes that rests on the top of the existing cross member for height alignment. If you can extend that drop down the rear face of the cross member to make sure the new one is fitted without a slope fore or aft, then so much the better. Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 13, 2018 Share Posted April 13, 2018 I used two lengths of 4 x 2 clamped to the chassis with some short lengths down to where the top rail fits, the body went back on near perfectly. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 13, 2018 Share Posted April 13, 2018 Same as above bolted steel on to the rails with bits down to align the height, had no problems with the 110 body going on . Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 13, 2018 Author Share Posted April 13, 2018 Thanks some great ides to think about. Don't suppose anyone has pics of when they done it. Quote Link to comment Share on other sites More sharing options...
