Howitzer Posted April 20, 2018 Share Posted April 20, 2018 (edited) Hi all, My 200tdi 110 commercial is getting a little tlc soon and I need a section of chassis replaced. i fitted an MIB rear crossmember a few years ago so that is fine but one chassis leg around the spring and behind it is flaking and expanding through rust. Just in front of the spring is solid. Where can I get chassis sections without the rear crossmember attached? The rest of the chassis is really good and I’d rather not patch it as it’s a keeper. Dave! Edited April 20, 2018 by Howitzer Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted April 20, 2018 Share Posted April 20, 2018 From what I’ve seen available it’s eithe a 1/4 or 1/2 chassis including the Cross member or buy some steel plates and female your own patches I’m afraid. Although if the patching is done correctly and all rotten metal is cut away and replaced with good metal, instead of just sticking the metal on top, you’ll get the exact same time out of it as if you’d bought a 1/4 chassis Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 20, 2018 Share Posted April 20, 2018 YRM do this channel section https://yrmit.co.uk/product/chassis-repair-section-land-rover-defender/ but if your on about the curved section I think you mean then you will have to put the bend in it yourself . Quote Link to comment Share on other sites More sharing options...
Howitzer Posted April 21, 2018 Author Share Posted April 21, 2018 Yeah that’s right, it goes from just behind where the ARB mountsbused to be to the front inner section of the spring mount. i think I’ll ring a few places when I get home to see if they would send me a rear quarter chassis in kit form. Dave! Quote Link to comment Share on other sites More sharing options...
