Red110 Posted May 4, 2018 Share Posted May 4, 2018 Hello, I would like to fit a VDO temperature gauge to a ZF 4HP-22 autobox. I have located the gauge (VDO 310 111) but not the sender, and so far my questions to Merlin, Croytec and Europa have got no answers at all. I would be most grateful if someone can give me the ref number for the sender, or at least its thread :):) Thank you, Pedro. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 4, 2018 Share Posted May 4, 2018 I think they normally go in the cooler lines, yes? Has it got a fitting there already? If not, then you could always put a fitting in there and screw on whatever matched sender you like. Quote Link to comment Share on other sites More sharing options...
Red110 Posted May 5, 2018 Author Share Posted May 5, 2018 In their web site Ashcroft recommend installing the sensor in the converter outlet to cooler, rather than in the oil pan or sump, for a more correct reading. Does it suggest that there isn´t a fitting anywhere already? Quote Link to comment Share on other sites More sharing options...
