cactus Posted May 11, 2018 Share Posted May 11, 2018 Hi, bit of advice required please! Would a LT77 V8 gearbox fit a 200 tdi engine? I have my old gearbox to swap the bell housing over. Are the first motion shafts the same or.. Easily swapped? Finally is £300 a reasonable price for a good low mileage LT77 ? Cheers Barry. .. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 12, 2018 Share Posted May 12, 2018 Input shafts are different, both in length and diameter of spigot bush. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 12, 2018 Share Posted May 12, 2018 There is a lr part spigot bush to fit a 200tdi into a v8 range rover classic. The part number is difficult to find as it was part of the retro fit kit sold by lr to fit 200s into range rovers. Mike Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2018 Share Posted May 12, 2018 1 hour ago, miketomcat said: There is a lr part spigot bush to fit a 200tdi into a v8 range rover classic. The part number is difficult to find as it was part of the retro fit kit sold by lr to fit 200s into range rovers. Mike Most likely this bush then LFB500050 1 BUSH-CRANKSHAFT, ENGINE CODE 4L 2.5 TDI MANUAL - 'AIRCON', ALSO SERVICED AS PART OF A KIT, 2.5L I4 200 TDI L/R, 5 SPEED MANUAL TRANSMISSION, LESS CATALYST Brit-car list the above as a number change from the Defender version https://www.brit-car.co.uk/product.php/99139/1074/spigot_bush___crankshaft___2_5l___defender as does LRDirect https://www.lrdirect.com/LFB500050-Bush/ Quote Link to comment Share on other sites More sharing options...
