reb78
GKN Overdrive Strip Down
I contacted the guy ages ago and he never has stock. I have no doubt that it will help to add a larger capacity for oil. Plus a sump plug will speed up oil changes and make them easy to do regularly. David (Vulcan Bomber) on here is looking at making something similar. Discussion here:
Share this post
Link to post
In my experience I don't think the majority of these GKN overdrives are robust enough for modern use. I'd certainly go Roamerdrive (alas hens teeth s/h, if one comes up grab it quick !) if I were to consider an overdrive again, a big investment for sure but proven to be capable and reliable.
Mo
Share this post
Link to post
I think the recommended oil changes (50,000km) are a big reason for the failures. 750ml of ATF in there for that time..... Mine is on 100,000 miles with me now and it was secondhand when I bought it, so they can go on ok.
Agreed though the Roverdrive does seem like a more robust unit.
Share this post
Link to post
Had a reply from Martin at D4x4, can't help with sprag outer ring or planet gear set, also spoke to overdrive -repairs, he hasn't got any sprag outer rings or planet gear sets in the housings either, looks like I'll have to scrap my GKN &/or look for a 2nd/3rd hand unit, or save up for the Roamerdrive unit.
just found this on ebay https://www.ebay.co.uk/itm/Roamerdrive-Overdrive-Unit-for-Land-Rover-Defender-90-110-130-DA9017/202371073807?hash=item2f1e41870f:g:yRUAAOSwgmJX1br~ glad I was sitting down when the price appeared. :o
my GKN was bought 2nd hand from a fellow 110 owner on the old LRO site quite a few years ago, it's had a good run. according to my original fit photo's I bought it June/July 2005. IIRC it had approx 10,000 miles on it then.
Share this post
Link to post
Even though mine was a total bargain I have to say for £1600 brand new I'd buy it again without a second thought. Especially after seeing the pics in this thread :ph34r:
  • Like 1
Share this post
Link to post
been digging up dates/mileage. fitted july 05, removed Feb '17, been on 110 for 117402 miles but obviously not engaged for all that time.
there's one GKN unit on ebay in germany for over 1700 quid, but think I'll save up for a roamer unit instead. quite fancy a 3rd gearlever to play with :)
Share this post
Link to post
I think Neil (V8Freak) may have a surplus GKN now that he's auto, might be worth a pm Ralph.
Mo
  • Like 1
Share this post
Link to post
Western Ralph,
There's a s/h roverdrive for sale on a french (non-specialist) site for 850€... I've pm'd you a link and can liaise if needed....
  • Like 1
Share this post
Link to post
The Roamerdrive is good, but it's no silver bullet.  I don't know about later units, but early ones had cheap bearings that were not quite true in mine.  They're very susceptible to low transfer box oil levels and hard to rebuild if that does happen (guess how I know).  On the plus side,  all I had to do was replace the failed bearings (no loss, since they were already horrible) and have the sun shaft bearing surface turned and sleeved.  To withstand what it did and be so simply repaired (ignoring the physical difficulty of parts of the job) is testament to its overall ruggedness.  Just watch the oil level!
Share this post
Link to post
Already had a PM from Mr V8Freak ref his dormant GKN unit & a PM from Giles about the other OD on the french webpage, Thanks both, PM's have been replied to.
Share this post
Link to post
just to update this, I bought V8Freaks unit from him & managed to get one of these bigger sumps [waiting on delivery] http://maximum--overdrive.com/products.html
Deep Sump,
Larger than any other on the market.  It will work on J&P type overdrives.  Will increase oil capacity and cooling.  Recommended for heavy duty applications.
Share this post
Link to post
Hey! That's mine, it's even got my name on it ! 😂
Mo
  • Haha 2
Share this post
Link to post
Mo
:rofl: No it's mine, or at least the one I bought is.
  • Haha 1
Share this post
Link to post
Mo
Turn it the other way around and it has Nige's middle name -"ow"!
  • Like 1
  • Haha 2
Share this post
Link to post
Deep Sump,
Be curious to know if it retains the small gauze filter and whether the oil pickup is extended into the sump or not when you get it Ralph. Also whether it still has a magnet glued in there as I find mine does catch some fine particles. The fella selling these wasnt that helpful when I contacted him previously - didnt seem to know when he might even expect stock!
Share this post
Link to post
He had this in stock, but it's taken me nearly 3 months to get hold of this item, he doesn't work at these as a fulltime job, my first email was on 19 Oct, my last reply from him was 15 Dec, had to extract the parcel tracking number from him as well, customs charges were paid this morning & I'm expecting delivery tomorrow, if it comes after 11.30am, [ I'll be at work after]  then I'll have to collect from post office on Weds morning. I'll add some photo's of the inside when I get my grubby mitts on it.
Share this post
Link to post
Well it's here.  photo's because you all want to see the item,
the bigger sump has a drain plug which has a inbuilt magnet, also comes with new longer bolts/spring washers & gasket, just found out what the short tube is for [to extend the gauze filter into the deeper sump, Thanks to soutie for the link above, a few posts on that link are corrupted, but it gives a good idea of  how it fits.
Share this post
Link to post
I think this will be a very worthy addition to the GKN. I have no doubt this will help reduce wear and also make maintenance easier with the drain plug!! I plan to fit something similar very soon hopefully. Even so, I would still recommend changing the ATF at every engine service.
  • Like 1
Share this post
Link to post
Fitting of the 'new to me' GKN & this sump will be a 2019 job now, when we get a good dry weekend.
Share this post
Link to post
My gkn overdrive was playing up badly with slipping gears mostly. I changed the atf oil and cleaned the filter and it worked like new for A few thousand miles. Its now leaking oil between the transfer box and the gkn, anyone got advice? Is it a big job to remove it and can i return the defender to being used without an overdrive. ?
Share this post
Link to post
Fairly easy to remove, you need the original transfer gear, cover plate, gasket, bolts to put transfer box back to standard form.
Share this post
Link to post
Well in process of fitting the new to me overdrive, also found that the big sump I bought doesn't fit with the transfer box big sump fitted, they both need to occupy part of the same space, so will have to make do with OD existing oil capacity. 2 photos below show the problem, may see about having the overdrive sump modified so the corner that clashes is removed & plated or welded up. Also the 6 bolts supplied are Not the same thread as the GKN bolts.
Share this post
Link to post
