Measurements
uninformed
Hi all , I require some measurements if possible.
The width of a disc brake Sals 110 axle housing flange to axle housing flange
The thickness of the axle housing flange on a DRUM brake 110 Sals
The thickness of the mounting surface on a 1995> disco rear stub axle - FTC3188 (with the scollop cut out for ABS) - also defender rear 2007 onwards
cheers
Serg
