bushwhacker Posted May 17, 2018 Share Posted May 17, 2018 Hi, any easy way to fix this wonky holes for the bottim of the front shocks both sides the same. Or maybe just leave them ? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 17, 2018 Share Posted May 17, 2018 Paddocks sell galved ones for £6 so Id just buy new ones . cheers Ian Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 17, 2018 Share Posted May 17, 2018 It’s part of the spring seat, which is welded to and forms part of the the axle casing. I think Ian may be referring to the bolt-on bit that goes on top, and which the spring actually sits onto. Those are a seperate part and easily replaceable as suggested, however they do not wear as such - just rust. YRM sell replacements, you need to cut the old ones off and weld new ones on. I did mine last weekend as it happens. A temporary fix is to weld a big M20 washer over the top. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 17, 2018 Share Posted May 17, 2018 Ah can see know the bolt on plate is still attached to the axle , sorry . Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 17, 2018 Share Posted May 17, 2018 I was wondering about drawing/designing some kind of easy locating weld in section to fix it without replacing the whole seat. Quote Link to comment Share on other sites More sharing options...
