FridgeFreezer Posted May 29, 2018 Share Posted May 29, 2018 After managing to snap a drive flange bolt I've bought 5x new ones but FC110107L is superseded by RYG101010L which is flanged, whereas the old ones weren't and had a split washer (WL110001L) underneath. Can someone tell me if I should fit the washers or not? Vehicle is 1988 127", standard, drum brakes, oil-filled hubs, metric. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 29, 2018 Share Posted May 29, 2018 Mines a 1993 200tdi and I’ve got the split washers fitted with them bolts , and I’ve just looked in my Land Rover parts book and they’re listed in there with them bolts and the split washers . Cheers Ian Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 29, 2018 Share Posted May 29, 2018 Unless you loctite them in place, yes you will need them.... Coming to think of it, I think they are loctited on my RRC.... may explain that bit. The bolts may be a different part number, that I couldn't tell you. Personally, if the bolts goes in far enough to torque down properly (i.e. the hole in the hub is deep enough) I would just go with loctite. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 29, 2018 Share Posted May 29, 2018 I think the new type come with thread locking compound pre-applied. The ones I bought for my 110's axles certainly did. The old type used spring washers and no thread-lock. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 29, 2018 Author Share Posted May 29, 2018 The new bolts are indeed pre-loctited, guess I can go without washers then... and after spending several pence on a set of washers, too! Quote Link to comment Share on other sites More sharing options...
