western Posted June 2, 2018 Share Posted June 2, 2018 Had to replace my 110's 200tdi's oil cooler hoses today, the 24 year old originals were leaking from the hose to rigid pipe swaging, so some new hoses are now fitted. mine are ESR 1912 upper & ESR1913 lower. both use have a straight end with a 'O' ring seal [these hoses came as part of my LR repower kit STC939D [TD to 200Tdi] back in mid 1994. the pipes above require rad/oil cooler adaptors ESR1262, there are also ESR280 & ESR281 for the same positions but with different end fittings these have a bell or domed end fitting, a bit more info on the rad end adaptors in http://www.defendersource.com/forum/f6/200tdi-oil-cooler-oil-cooler-line-thread-question-23281.html the oil filter head is different too, where the hoses screw in the filter head for the ESR280/ESR281 have a dished seat for the hose ends, whereas the head [not 100% sure of the part number] for the ESR1912/ESR1913 is straight. ESR1912 filter head end ESR1912 oil cooler end ESR1913 oil cooler end ESR1913 filter head end ESR280 filter head end ESR280 oil cooler end ESR281 filter head end ESR281 oil cooler end filter head seats for ESR280/ESR281 end fittings Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2018 Author Share Posted June 2, 2018 bit more info & photo's of the oil filter head in this I wrote back in 2015, photo's in reply dated 13 may 2015 show the differences Quote Link to comment Share on other sites More sharing options...
