western Posted June 4, 2018 Share Posted June 4, 2018 On my 110 I've replaced my normal indicator lights with led version [RDX] with their matching flasher unit, I want to fit a buzzer into the circuit as I can't hear the flasher unit click when indicators are on. lights are working fine, td5 warning light panel so seperate L & R indicator telltales do I need 2 buzzers [one each for left & right] or 1 buzzer & other than a earth connection which wire should it/they be connected to ? my 110 is a 1989 110CSW. standard dash/main wiring loom. Quote Link to comment Share on other sites More sharing options...
crwoody Posted June 4, 2018 Share Posted June 4, 2018 I'd say one buzzer and two diodes. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 4, 2018 Share Posted June 4, 2018 Go to the quacks and get your hearing checked Seriously, the above solution would work well, just connected to the left and right feeds for the lamp units or dash telltale. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 4, 2018 Share Posted June 4, 2018 Green/White and Green/Red, I think. 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2018 Author Share Posted June 4, 2018 Don't need the doctor. its just a very quiet flasher unit, even the old bulb one wasn't very loud, Cheers that's a fairly easy thing to sort, any particular type/size of diodes to obtain ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 4, 2018 Share Posted June 4, 2018 1N4001 would be plenty and very, very cheap. Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2018 Author Share Posted June 5, 2018 Should be able to source those on ebay or RSonline, now maplin have gone. these would do ? https://uk.rs-online.com/web/p/rectifier-schottky-diodes/6288931/ Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 5, 2018 Share Posted June 5, 2018 Ebay sell them 10 to a pound. 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2018 Author Share Posted June 8, 2018 sourced 2 buzzers & some doides off ebay, should be here by next weekend. buzzers https://www.ebay.co.uk/itm/Miniature-Electronic-Buzzer-Project-Sounder-Leaded-PCB-Black-White-1-5-3-6-12V/251550077147?ssPageName=STRK%3AMEBIDX%3AIT&var=550454921813&_trksid=p2057872.m2749.l2649 diodes https://www.ebay.co.uk/itm/1N4001-Diode-50V-1A-Pk-of-10/201974314641?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I suspect I only need one of the buzzers, with each diode wire connected to the red [live] wire of the buzzer & the black [earth] to a suitable earth point |& other end of diode on each of the left & right indocator dash light wires, these are easy enough to access with instrument pack moved out of it's fixings. Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2018 Author Share Posted June 15, 2018 got my buzzers & diodes this week, thinking that I've got a Td5 instrument pack/warning light panel & the L & R indicators have seperate lights in the warning light panel, maybe I don't need the diodes, just wire in the red 12v feed on each buzzer to each ind warning light wire & the black on each buzzer to a earth point. or if I just use one buzzer then make sure a diode in each ind wire to buzzer to stop the feed going to the other indicator light [which are led on the warning light panel] Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2018 Author Share Posted June 15, 2018 in addition to my above post, this is what I intend will it work ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 15, 2018 Share Posted June 15, 2018 Yup! 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2018 Author Share Posted June 15, 2018 Perfect, Thanks very much for confirmation, I can get this done in morning. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 16, 2018 Share Posted June 16, 2018 Can't you just have a spur to a single buzzer from the output of the flasher relay? No need for diodes, only one piece of insulation disturbed and only one buzzer needed. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2018 Author Share Posted June 16, 2018 Nope, cos I have led indicators all round & the buzzer sounds soon as ignition is switched on, with indicators not operating. but a spur of the flasher unit wire did work ok with the original type indicator lights. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2018 Author Share Posted June 16, 2018 buzzer & 2 diodes fitted, here's the result. WP_20180616_14_22_52_Pro.mp4 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 16, 2018 Share Posted June 16, 2018 I forgot that Defenders have their switches on the earth side, so a buzzer between the indicator switch and earth should have worked. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2018 Author Share Posted June 16, 2018 Indicators switch is on the live feed side, earth is at each light unit to body/chassis. found another little thing to sort out. now the 110 has a full set of RDX/Bolt-on-bits led indicators & their matching 4 pin flasher/hazard unit. when my trailer is connected [also has led indicators] the trailer ind green warning on my dash doesn't light when 110 & trailer left or right indicators are on. I've found on the RDX flasher unit info sheet it say this light will not operate if the trailer does not havve load resistors in the indicator circuit, so I've just bought a pair off ebay & will see what happens once they are fitted. hopefully everything will work as it should, doing this simply because a trailer ind light on dash is a legal requirement with trailer connected. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 17, 2018 Share Posted June 17, 2018 Well done Ralph. That buzzer is suitably annoying and you’ll hate it at busy junctions.... But never leave the indicator on again for sure.... Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted June 17, 2018 Share Posted June 17, 2018 Western am i right in thinking that you fit the load resistors to the trailer with the led so that you can still tow a “standard “ trailer? Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2018 Author Share Posted June 17, 2018 It'll do the job Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2018 Author Share Posted June 17, 2018 3 minutes ago, Roverdrive said: Western am i right in thinking that you fit the load resistors to the trailer with the led so that you can still tow a “standard “ trailer? Yes, they will be fitted to the trailer near the rear lights as I can access the wiring fairly easy. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 17, 2018 Share Posted June 17, 2018 Did you adjust the flasher? The adjustment is to set the trailer light. Quote Link to comment Share on other sites More sharing options...
western Posted June 18, 2018 Author Share Posted June 18, 2018 (edited) Yes as detailed on the RDX instructions which does say about trailer light will work if trailer indicators are load resistor fitted, at work now but will upload the info sheet later. I've underlined the bit about trailer with NO load resistor but with LED lights Edited June 18, 2018 by western attachment added Quote Link to comment Share on other sites More sharing options...
