Muttland Posted June 6, 2018 Share Posted June 6, 2018 Hi to all: The discovery Td5 uses the arm of Cluth Fork N ° 576137 of casting. Is this the same as using the clutch fork arm of santana 3576138? Are they interchangeable? Can it be used in a Tdi 300 to impersonate the lightest of sheet steel? The modelo 576137 is used in others LR like a 101, Disco V8, and Td5 too, is the same that use the Serie 3 made in England? Thanks Quote Link to comment Share on other sites More sharing options...
