2001 TD5 rear window.
So far as I remember the 2001 defender with a two-piece rear door, (squared-off bottom corners,) used aluminium angle sections, screwed in from the inside to hold the window in place, sealed with mastic, the later pressed steel door with rounded bottom corners, uses a conventional window seal the same as the front screen. None are actually bonded in the way that "modern" screens are fitted.
Edited by crwoody
