Smego Posted June 14, 2018 Share Posted June 14, 2018 My 30 year old 110 is in for it's service and the dreaded MOT today 😟 Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2018 Share Posted June 14, 2018 it'll be fine  Quote Link to comment Share on other sites More sharing options...
Smego Posted June 14, 2018 Author Share Posted June 14, 2018 (edited) Failed on head light beam angle which is wierd as not been touched, small hole to weld in exhaust, rear brakes and hand brake tweak (same every year) and needs a new drivers seat belt as normal cuaght in door issue, I know you can get the differant strikers but has anyone used pads or anything else over the actual belt to protect them as when I changed the passenger one 2 years ago I taped a freebee shoulder pad over the belt and that had protected it, will do the same on drivers unless anyone has a better idea? The old beasty had had a full fluid change including diffs so will live another year once the new belt turns up! Edited June 14, 2018 by Smego Spelin. Quote Link to comment Share on other sites More sharing options...
Smego Posted June 14, 2018 Author Share Posted June 14, 2018 Wierd he had missed the fact the frint number plate is only held on by one side cable tie and the left hand side rear light wire is not plugged into the towing socket 😳 Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2018 Share Posted June 14, 2018 front reg plate is easily readable & no obstructions, probably didn't notice it only had one fixing. the 12N towing socket is not tested that's only on the EURO 13 pin type sockets, on yours & mine its just a visually to ensure its all safely secure. should've tweaked the brakes before going, did he readjust the headlights for you. ? in all no majors issues to overcome.  Quote Link to comment Share on other sites More sharing options...
Smego Posted June 14, 2018 Author Share Posted June 14, 2018 He is gping to fit a bit of pipe invthe exhaust down pipe as easier, I have ordered a new seat belt and he has orderwd new front brake pipes to go in next week :¬} Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 15, 2018 Share Posted June 15, 2018 18 hours ago, Smego said: Once the new belt turns up! Smego, any chance I could nick the old belt off you, if you're fussed you can have it back afterwards? I'm changing over the rear seats in mine to a set from an L322 but the original rear belts are just a little bit too short. I think the front ones are a bit longer so might be a suitable replacement. If you're getting one off the vehicle will help me test the length without having to remove mine. Only up the road in Tongham. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted June 15, 2018 Share Posted June 15, 2018 any chance of a photo of the 'damage' to the seat belt, that would cause it to fail. Mine has lots of 'squash' marks, so wondering what 'damage' looks like. Quote Link to comment Share on other sites More sharing options...
Smego Posted June 16, 2018 Author Share Posted June 16, 2018 Ed, of course only heading for the bin. Yo, will try to remember to take one, basically just a bit threadbare due to being slammed in the door a few times. Quote Link to comment Share on other sites More sharing options...
Smego Posted June 16, 2018 Author Share Posted June 16, 2018 16 hours ago, Ed Poore said: Smego, any chance I could nick the old belt off you, if you're fussed you can have it back afterwards? I'm changing over the rear seats in mine to a set from an L322 but the original rear belts are just a little bit too short. I think the front ones are a bit longer so might be a suitable replacement. If you're getting one off the vehicle will help me test the length without having to remove mine. Only up the road in Tongham. Out of interest how do you know it is only up the road? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 16, 2018 Share Posted June 16, 2018 6 hours ago, Smego said: Out of interest how do you know it is only up the road? Pretty sure (unless I've got it wrong) I've popped around before so you could have a look at the height of my 110 as you thought yours was riding low. White, would have been station wagon at the time. Quote Link to comment Share on other sites More sharing options...
Smego Posted June 16, 2018 Author Share Posted June 16, 2018 Ah of course Ed, ling time ago when I was on the original tired old springs now I remember! Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 16, 2018 Share Posted June 16, 2018 Digging through PMs I still have your contact details so when I'm back home (farm sitting at the moment) next week I'll get in touch. Quote Link to comment Share on other sites More sharing options...
Smego Posted June 23, 2018 Author Share Posted June 23, 2018 Have the seat belt but had to cut it away from the lower mount Ed. Quote Link to comment Share on other sites More sharing options...
