slihp Posted June 20, 2018 Share Posted June 20, 2018 Noticed a knocking coming from the front. There is play in the fan and its hitting the cowling on top. The fan is on tight but there is some movement when its still so assuming its the bearings in the fan. Is this a new fan job or can you get new bearings? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 20, 2018 Share Posted June 20, 2018 IIRC Colin Reed Reedex.net did some work on this to see if the bearings could be changed. If not it means a new front cover unless anybody knows different Quote Link to comment Share on other sites More sharing options...
Stambecco Posted June 20, 2018 Share Posted June 20, 2018 Would that mean the water pump is on its way out? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted June 20, 2018 Share Posted June 20, 2018 (edited) 3 hours ago, Stambecco said: Would that mean the water pump is on its way out? No, on a TD5 the water-pump lives in a housing behind the PAS pump and is driven from an extension on the rear of of the PAS-pump: the only thing it has in common with the viscous fan is that they share a drive-belt. Edited June 20, 2018 by Tanuki 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 20, 2018 Share Posted June 20, 2018 I presume slihp is talking about play in the viscous unit itself? Quote Link to comment Share on other sites More sharing options...
slihp Posted June 20, 2018 Author Share Posted June 20, 2018 yes the play is all in the fan nothing else Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 21, 2018 Share Posted June 21, 2018 I would suggest removal of the fan and take a good look at the whole viscous unit.... Quote Link to comment Share on other sites More sharing options...
slihp Posted June 21, 2018 Author Share Posted June 21, 2018 Dose the fan separate into components. I did notice you can buy a roller bearing for them but they are still pricy so might be better getting new. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 22, 2018 Share Posted June 22, 2018 I had my 300Tdi timing cover modified with a new custom shaft and off-the-shelf bearings for about the same price as a new cover and bearing (not available separately and a very unusual bearing). That way, future replacement will be cheaper and easy. There will be details and photos on the RRC section of my blog. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted June 23, 2018 Share Posted June 23, 2018 This still feels a bit ambiguous about what is being talked about. Either the fan pulley bearing or the viscous unit bearing itself. Take the fan off and check for play in this nut in the photo below. I have seen one where the fan viscous bearing has disintegrated and this nut is rattling around. Then check for play on the fan pulley. Details on changing the fan pulley bearing: http://www.discovery2.co.uk/Fan_bearing.html Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 24, 2018 Share Posted June 24, 2018 ive changed the viscous fan bearing on a td5 before, not particularly difficult, just more of a faff, bearing was expensive if I remember correctly, to change the front cover would involve taking the head off Quote Link to comment Share on other sites More sharing options...
