Farky Posted June 27, 2018 Share Posted June 27, 2018 May be a stupid question but is there a measurement so you can tell if your vehicle is fitted with standard wheel arch’s or plus 2’s for example? I need to replace one on my defender but want to make sure they are just standard ones cheers Quote Link to comment Share on other sites More sharing options...
ballcock Posted June 28, 2018 Share Posted June 28, 2018 If you are on about extended width arches then they should be reasonably obvious. but if you look underneath I believe the original arches are the only ones that bridge the gap to the inner arch where as the others finish at the wing. hope this helps. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 28, 2018 Share Posted June 28, 2018 Easily sorted with a picture! From memory the standard arches are 70mm from the body to the outermost edge. Quote Link to comment Share on other sites More sharing options...
