tdi Posted July 1, 2018 Share Posted July 1, 2018 I have a question for those of you who have front-facing folding rear seats on your 90 or 110. When the brackets and seats are mounted as shown in the attached photos, and the seat is latched downward onto the bracket, there is a gap of approximately 0.2-0.25" between the pointed tops of the lower bracket and the seat frame as shown. 1. Is the seat frame supposed to be resting on the pointed tops of the bracket? 2. is there supposed to be some kind of bumper or something between the pointed tops of the bracket and the seat frame? 3. Is the gap supposed to be there? Quote Link to comment Share on other sites More sharing options...
justustwo Posted July 10, 2018 Share Posted July 10, 2018 IF you are putting the puma rear seats into an older tdi then you need to add spacer blocks as the the wheel arch boxes of the puma and tdi are different Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 10, 2018 Share Posted July 10, 2018 Or you could fit the wheel arch mod panels by yrm I think. Mike Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted July 13, 2018 Share Posted July 13, 2018 It's a fairly comprehensive "tweak" to the tub...the kit includes the recessed skins for inside the tub as well as the strengtheners that go underneath and the chassis brackets. It's as close to factory as possible Quote Link to comment Share on other sites More sharing options...
