Northern Paul
Guidance on removing front sidelights & indicators Ex Military 90
Good morning,
 As per the title thread really. I have limited electrical / mechanical knowledge & have removed the screw on lenses & bulbs. How do I remove the lamp units from the wing panels?
 Any guidance or pictures would be gratefully received. I am at work for another week or so thus have no access to the vehicle presently.
 Cheers, Paul
Share this post
Link to post
Easier done than explained,  Unscrew front glass cover, remove bulb.  You’re now looking at a circular plate that has what looks like a black rubber washer round it, this is the front lip of the water proof shroud that extends through the wing.  Carefully and easy, prise this lip/shroud out towards you clear of the indicator body.  You should see 2/3 screws that hold the indicator body to the wing, remove screws and the body will come forward allowing you to disconnect the wires.
Share this post
Link to post
I find it easiest to push the bulb holder from the back to get it out.
Share this post
Link to post
Yep you’re right.  I was remembering the rear light I took out, the back end was full of wet mud so I winkled it out from the front to save me getting caked.
Share this post
Link to post
Hello again,
 I got massively distracted last time I was home and only had a quick look at the lights; I saw how they came out but didn't actually remove them.
 I'm toying with the idea of replacing them with standard style lamps but Wipac LED versions; I run lamp guards & the Wipac LED maps are waterproof to IP67 which should suffice for my offroading these days.
 Question is; once I have removed the original military lights, are the standard 73mm lights a straight swap.
 Also, any reason not to do this?
 Cheers, Paul
Share this post
Link to post
If you do the indicators, you will also need to fit a new flasher relay and modify the dash indicator light or fot load resistors.
Share this post
Link to post
They are just lights that screw on the outside of a flat panel.  Anything will work.
Share this post
Link to post
