Tool organisation (in vehicle)
Last year when the hinges on my teng cases started to split...
I looked for alternatives as the teng cases are not available on their own. I still wanted portability, and I like the set cases as you know when a tool is missing, misplaced when you’re packing up.
So the Solution I went for was to pick up some Bosch tool boxes made by Sortimo and fit some foam inserts from shadow foam...
I went for the 136 boxes, about £20-25 on eBay as they can fit two tool trays inside, but they’re available in numerous sizes. I got some ally plate bent up to size too, to hold the top shelf...
You then have the laborious task of cutting out the foam with a scalpel, before they were ready...
BDA74B95-44FC-41B3-839B-57C3FDC2F48F.thumb.jpeg.e2cc64067720087ddf496c7b98286522.jpegF59A479A-9414-4285-8EB5-D7CCDABF2033.thumb.jpeg.8722016dafdc39dfb1ba3b57524abee1.jpeg36E60E67-EDDD-4C3A-832C-5AF0AE4A78AB.thumb.jpeg.37a75c885f14c0801fabf5b402425a06.jpeg
They are designed to stack on top of each other clipping in securely, and you can get some clips to secure the the first box to a shelf, floor etc.
Sortimo does a bunch of other accessories, tray insert and boxes etc. although they’re quite pricey when buying them from Sortimo...
https://www.sortimo.co.uk/shop/en_UK/BOXXes-%26-Cases/L-BOXX-family/c/47834?q=:tsa
Theyve worked out well, very sturdy, stack well and as intended very portable. The only downside is if a tool breaks and you can’t get a like for like replacement your screwed unless you get out the scalpel again. ;);)
  • Like 3
  • 2 weeks later...
