Cornish Rattler
Just bought a metal detector
Finding the bits that have dropped off?
  • Haha 1
Share this post
Link to post
Yeah there must be loads of nuts, bolts and washer's I've lost over the years ☺️
Share this post
Link to post
Always useful if you've ever lost a nut or bolt in the grass or stone drive :)
Alternative... Big old speaker magnet on a string.... Dragged back and forth over the suspect area... ;)
Share this post
Link to post
The only thing is the detector I've bought is for beach detecting and won't be much use on land ☹️
Share this post
Link to post
The beach isn't land?
Share this post
Link to post
On 7/21/2018 at 9:03 PM, Cornish Rattler said:
Hi guys
For when the landy is back on the road...
...so you can find good bits of metal to weld to?
Share this post
Link to post
The minerals in beach sand are different to the minerals in soil or what ever, you can use a land metal detector on a beach and a beach metal detector on land but they will give a lot of falls readings as they both have different sensertivities depending what you are looking for, also beach detectors can work under water aswell which mine will do but most land detectors won't, think that's how I've been told and read up but I could be wrong as I am still a novice at this ☺️
Share this post
Link to post
Gave it a quick try in the garden yesterday using an old washer and it worked ok but the real test will be on a beach which is what its intended for ☺️
Share this post
Link to post
...well I've learnt something, thought soil was soil, didn't know that you get land and beach detectors , thanks
Share this post
Link to post
No I didn't either as I was going to go for a Garret ace 250 which isn't a beach detector but lots of detectorist's use them one beaches as they are pretty good but ive watched a few tests comparing the ace 250 and the 4pi and the 4pi is a far better machine so I will have to see ☺️
Share this post
Link to post
Mate of mine went beach detecting once got all the signals beeps ect, dug down two foot and realised he's got steel toe cap boots on, dd
Share this post
Link to post
Haha yeah you've just reminded me my wellies are steel toe caped so will have to get new ones :D
Share this post
Link to post
I've just ordered a plastic shovel to mod for metal detecting ( drill loads of holes into for drainage and to cut the sides down to allow it to cut into the sand ) :)
Share this post
Link to post
The higher end detectors can be set to a wide variety of different soils/sands/moisture contents, etc. Indeed, if you've a mind to, some of them can be programmed to custom discrimination maps. I can't be bothered to do that with mine though, so just select the appropriate settings and off I go!
Share this post
Link to post
Yeah I will see how this one goes then I mite upgrade to something better later :)
Share this post
Link to post
