lindsayfraser Posted July 24, 2018 Share Posted July 24, 2018 I was wondering if any one who has modified their vehicle by, by passing the air flow meter. I heard that it was done by connecting the positive wire from the throttle connecting to the positive wire to the computer. Has anyone heard of this. I believe it gives instant throttle response. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 24, 2018 Share Posted July 24, 2018 Can't see why bypassing it would give any benefit at all. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted July 25, 2018 Share Posted July 25, 2018 That is absolute nonsense. You bypass that and you’ll make it run like a turd Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 25, 2018 Share Posted July 25, 2018 Sounds like a horrible horrible bodge dreamt up by someone who doesn't understand how any of that stuff works. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 25, 2018 Share Posted July 25, 2018 Ditto the above, nasty bodge Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 25, 2018 Share Posted July 25, 2018 If you just unplug it, the ecu uses default values. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 27, 2018 Share Posted July 27, 2018 ^ What he said. Just unplug it. Runs better if the AFM is broken (they usually fail and under-read the airflow leading to reduced fuelling and a loss in power), so will help diagnose that, but a working AFM is the best option. If you want instant throttle response unplug the clutch sensor to disable the anti shunt control. But it'll be so jerky to drive you will most likely plug it back in again Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted July 27, 2018 Share Posted July 27, 2018 On 7/25/2018 at 10:33 PM, reb78 said: If you just unplug it, the ecu uses default values. technically it doesn't, it uses the throttle pedal vs Map sensor as a lookup Quote Link to comment Share on other sites More sharing options...
