roamingyak Posted July 24, 2018 Share Posted July 24, 2018 (edited) My 1991 front doors cards are all dynamatted and foam covered and ready to go back on the doors. Is it worth ordering some of the original plastic waterproof sheets to fit? (Or will the newer shredders fit also?) Edited July 24, 2018 by roamingyak Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 24, 2018 Share Posted July 24, 2018 Yes; they stop a lot of drafts. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted July 24, 2018 Author Share Posted July 24, 2018 8 hours ago, Snagger said: Yes; they stop a lot of drafts. OK, which ones should I get - old style or new shredders (assuming they fit?) Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 25, 2018 Share Posted July 25, 2018 I haven't seen what you mean by "shredders". I didn't notice any difference in drafts between the old, early push button 110 doors and those on the late models, as long as the doors were adjusted to close properly. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted July 25, 2018 Share Posted July 25, 2018 Later puma shedders are foam for the steel doors. They may not be an exact fit on earlier doors but they probably work. Here's what they look like They may have a sound deadening property but other than that, if you ever go back inside the door then you have to cut it whatever it is Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 27, 2018 Share Posted July 27, 2018 They look to be made for electric windows, so could foul the manual winder mechanism, but they look easy to modify with a hot glue gun or contact adheive and will certainly be better for noise reduction. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted July 27, 2018 Share Posted July 27, 2018 It's the same part for both, with a scored area to push through the manual winders 1 Quote Link to comment Share on other sites More sharing options...
