freff Posted July 27, 2018 Share Posted July 27, 2018 I'm about to make a start on replacing the air springs on my 2001 D2 TD5. i am quite clear on the procedure except when it comes to de-pressurising the system. I don't really want to disturb the compressor if l can help it, or assassinate the bag with a sharp screwdriver. Can I use a SLS Air Suspension Key Fob that is normally used to lower the suspension when hitching heavy trailers etc, I assume it would deflate the system, but unsure if I might encounter any problem. Many thanks for any help. Tony Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted July 27, 2018 Share Posted July 27, 2018 Stabbing them with a sharp knife works well,you can then twist the knife to control the rate of deflation. I usually support the car properly to stop it from lowering. I then cut the bags right in half to make them very easy to remove. It also means nobody is tempted to try reusing them. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 27, 2018 Share Posted July 27, 2018 Not sure if this is the approved method (or even if it works for everyone) but I noticed a while ago that after having my D2 on axle-stands under the chassis so that the axle was hanging, and running the engine, when I put it on it's wheels again the bags were totally deflated... Quote Link to comment Share on other sites More sharing options...
sierrafery Posted July 27, 2018 Share Posted July 27, 2018 2 hours ago, Ally V8 said: Stabbing them with a sharp knife works well,you can then twist the knife to control the rate of deflation. I usually support the car properly to stop it from lowering. I then cut the bags right in half to make them very easy to remove. It also means nobody is tempted to try reusing them. +1 for that^^^ simple and efficient Quote Link to comment Share on other sites More sharing options...
