Maverik Posted July 27, 2018 Share Posted July 27, 2018 Hi folks, having to lean on the brain trust for this one, I'm looking to identify the red circled terminals, I've worked out the small terminals are Standard power timer terminals, but I can't for the life of me track down the larger female blade type ones, anyone have any pointers at all? Cheers Mav Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted July 27, 2018 Share Posted July 27, 2018 Without a sense of scale they just look like standard 1/4" terminals. Note there are many different varieties because some of them have little tabs on for locking into holders like this. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 27, 2018 Share Posted July 27, 2018 I'd say so too, but they will have tangs in them to hold them in place. Will be *SOMETHING* like this: http://www.vehicle-wiring-products.eu/product.php/429/female-blade-with-latch It used to be possible to order the entire plug from Audi, and it included the crimps, may be worth checking if they still do it? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted July 28, 2018 Share Posted July 28, 2018 (edited) VAG terminals (pre-crimped to a length of cable) to fit the above pictured relay base, are as follows - Cavities Terminal 1, 3, 7, 9 000 979 133 (1,0 mm²) 1, 3, 7, 9 000 979 225 (2,5 mm²) Cavities Terminal 2, 5, 8 000 979 135 (1,0 mm²) 2, 5, 8 000 979 227 (2,5 mm²) 2, 5, 8 000 979 306 (4,0 mm²) 2, 5, 8 000 979 407 (6,0 mm²) Cavities Terminal 4, 6 000 979 114 (1,0 mm²) 4, 6 000 979 212 (2,5 mm²) 4, 6 000 979 405 (6,0 mm²) The terminals for cavities 4 and 6, look like - TE (AMP) Positive Lock Connection System 6.3 mm (.250 Series) Mark I Female Receptacles - These can be bought from RS, Farnell, etc..., to suit various cable sizes, and in a number of different plated finishes. This one is - CuSn, unplated, to suit 1.0 to 2.5mm² cable - TE part number = 927854-2 RS part number = 669-2832 They're also available as - CuSn, pre-tin plated, to suit 1.0 to 2.5mm² cable - TE part number = 927854-7 RS part number = 669-2844 They're also available from Polevolt - https://www.polevolt.co.uk/acatalog/6.3mm_Terminals.html Ref: 3-7010/10 . Edited July 28, 2018 by PaulMc 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 28, 2018 Share Posted July 28, 2018 There's no bowing emoticon, but if there was, I would be doing it now Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 28, 2018 Share Posted July 28, 2018 ... it does seem to be a function of your user name Pete 😉 Paul is THE terminal God. Mo Quote Link to comment Share on other sites More sharing options...
JonathanR83 Posted January 12, 2019 Share Posted January 12, 2019 (edited) On Sat Jul 28 2018 at 3:40 AM, PaulMc said: VAG terminals (pre-crimped to a length of cable) to fit the above pictured relay base, are as follows - Cavities Terminal 1, 3, 7, 9 000 979 133 (1,0 mm²) 1, 3, 7, 9 000 979 225 (2,5 mm²) Cavities Terminal 2, 5, 8 000 979 135 (1,0 mm²) 2, 5, 8 000 979 227 (2,5 mm²) 2, 5, 8 000 979 306 (4,0 mm²) 2, 5, 8 000 979 407 (6,0 mm²) Cavities Terminal 4, 6 000 979 114 (1,0 mm²) 4, 6 000 979 212 (2,5 mm²) 4, 6 000 979 405 (6,0 mm²) The terminals for cavities 4 and 6, look like - TE (AMP) Positive Lock Connection System 6.3 mm (.250 Series) Mark I Female Receptacles - These can be bought from RS, Farnell, etc..., to suit various cable sizes, and in a number of different plated finishes. This one is - CuSn, unplated, to suit 1.0 to 2.5mm² cable - TE part number = 927854-2 RS part number = 669-2832 They're also available as - CuSn, pre-tin plated, to suit 1.0 to 2.5mm² cable - TE part number = 927854-7 RS part number = 669-2844 They're also available from Polevolt - https://www.polevolt.co.uk/acatalog/6.3mm_Terminals.html Ref: 3-7010/10 . Thanks for your post PaulMC !! I was looking for that. Can you please let me know what's the reference on Polevolt for Cavities Terminal 2, 5, 8 000 979 135 (1,0 mm²) If you have a Link on Polevolt.. By the same Time i am looking for the reference of the terminal on this Relay crimp Reference : 8E0 937 527 You will save my life!! My car is break down for two weeks because i Can not find the terminal. If you have a Link on Polevolt. thanks by advance mate! You are the BOSS 😊 Edited January 12, 2019 by JonathanR83 Word mistake Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 13, 2019 Share Posted January 13, 2019 18 hours ago, JonathanR83 said: Can you please let me know what's the reference on Polevolt for Cavities Terminal 2, 5, 8 000 979 135 (1,0 mm²) If you have a Link on Polevolt.. By the same Time i am looking for the reference of the terminal on this Relay crimp Reference : 8E0 937 527 VAG terminals to fit the relay socket 8E0 937 527 are - Smaller terminal To fit two cable sizes, both available as - A Repair Wire - 000 979 133 (1.0 mm²) A Crimp Terminal - N 906 844 05 (1.0 mm²) A Repair Wire - 000 979 225 (2.5 mm²) A Crimp Terminal - N 906 845 05 (2.5 mm²) Larger Terminal To fit one cable size, available as - A Repair Wire - 000 979 236 (2.5 mm²) A Crimp Terminal - N 103 197 01 (2.5 mm²) I can't find a match for 000 979 236 (N 103 197 01) from anyone other than VAG Polevolt sell relay terminals for the MTA Modular Fuse and Relay System, these look very much like the 'Timer' type terminals used in the VW relay sockets. 6.3mm Terminals for relay modules 1 - 2.5mm cable, Ref: 3-2030 6.3mm Terminals for relay modules 2.5 - 4mm cable, Ref: 3-2050 These look very much like the Terminal used on the Repair Wire - 000 979 135 Which is also available as a Crimp Terminal - N 907 326 03 2.8mm Terminals for relay modules 0.5 - 1mm cable, Ref: 3-5620 2.8mm Terminals for relay modules 1.5 - 2.5mm cable, Ref: 3-5630 These look very much like the Terminal used in the relay socket 8E0 937 527 above. Unfortunately, Polevolt don't ship outside of the UK. Vehicle Wiring Products will ship abroad - http://www.vehicle-wiring-products.eu/ http://www.vehicle-wiring-products.eu/product.php/750/terminals-for-micro-standard-relays-4-8mm-blade http://www.vehicle-wiring-products.eu/product.php/751/terminals-for-micro-and-standard-relays-6-3mm-blade . Quote Link to comment Share on other sites More sharing options...
JonathanR83 Posted January 14, 2019 Share Posted January 14, 2019 (edited) 19 hours ago, PaulMc said: Polevolt sell relay terminals for the MTA Modular Fuse and Relay System, these look very much like the 'Timer' type terminals used in the VW relay sockets. 6.3mm Terminals for relay modules 1 - 2.5mm cable, Ref: 3-2030 6.3mm Terminals for relay modules 2.5 - 4mm cable, Ref: 3-2050 These look very much like the Terminal used on the Repair Wire - 000 979 135 Which is also available as a Crimp Terminal - N 907 326 03 Thanks for your hard work PaulMC !!! Just a question, are you sure about the terminal reference for this one : These look very much like the Terminal used on the Repair Wire - 000 979 135 Which is also available as a Crimp Terminal - N 907 326 03 You gave to me the reference for a terminal on 6.33mm, it should be 4,8mm on the 000 979 125 isn't ?? Just confirm me if you are sure about that. Thanks again for your help ! Edited January 14, 2019 by JonathanR83 Quote Link to comment Share on other sites More sharing options...
JonathanR83 Posted January 15, 2019 Share Posted January 15, 2019 On 1/13/2019 at 9:20 PM, PaulMc said: VAG terminals to fit the relay socket 8E0 937 527 are - Smaller terminal To fit two cable sizes, both available as - A Repair Wire - 000 979 133 (1.0 mm²) A Crimp Terminal - N 906 844 05 (1.0 mm²) A Repair Wire - 000 979 225 (2.5 mm²) A Crimp Terminal - N 906 845 05 (2.5 mm²) Larger Terminal To fit one cable size, available as - A Repair Wire - 000 979 236 (2.5 mm²) A Crimp Terminal - N 103 197 01 (2.5 mm²) I can't find a match for 000 979 236 (N 103 197 01) from anyone other than VAG Polevolt sell relay terminals for the MTA Modular Fuse and Relay System, these look very much like the 'Timer' type terminals used in the VW relay sockets. 6.3mm Terminals for relay modules 1 - 2.5mm cable, Ref: 3-2030 6.3mm Terminals for relay modules 2.5 - 4mm cable, Ref: 3-2050 These look very much like the Terminal used on the Repair Wire - 000 979 135 Which is also available as a Crimp Terminal - N 907 326 03 2.8mm Terminals for relay modules 0.5 - 1mm cable, Ref: 3-5620 2.8mm Terminals for relay modules 1.5 - 2.5mm cable, Ref: 3-5630 These look very much like the Terminal used in the relay socket 8E0 937 527 above. Unfortunately, Polevolt don't ship outside of the UK. Vehicle Wiring Products will ship abroad - http://www.vehicle-wiring-products.eu/ http://www.vehicle-wiring-products.eu/product.php/750/terminals-for-micro-standard-relays-4-8mm-blade http://www.vehicle-wiring-products.eu/product.php/751/terminals-for-micro-and-standard-relays-6-3mm-blade . Hoooo i have done a big mistake !! I have just realized that i asked you the wrong parts of the relay 8E0 937 527 I need the terminals of the Pink Side ( 1/2/3/4/5 ) I don't think they are the same terminals that the blue side. Can you please let me know which one they are for the number 1/2/3/4/5 of the pink side. I am very sorry to ask you that again, you have done a wonderful job and i am very grateful about your help. Thank you again ! Quote Link to comment Share on other sites More sharing options...
