Keeper96 Posted August 2, 2018 Share Posted August 2, 2018 Hi folks I’m refitting the steering system to my series 3 rebuild and was wandering if people have any clues on how to ensure everything is fitted straight ahead? Such as where should the bottom and top arm on the steering relay point when in the straight ahead position? Amd any other tips are appreciated. Jamie Quote Link to comment Share on other sites More sharing options...
lo-fi Posted August 2, 2018 Share Posted August 2, 2018 The bottom arm should be straight ahead, the top offset a spline so the angle between is less than 90. The BGB gives lengths that the arms should be set to, which is usually enough to get everything else started. I can probably scan a page or two if you need. Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted August 2, 2018 Author Share Posted August 2, 2018 Hi Lofi, that would be great if you could do that? Cheers Quote Link to comment Share on other sites More sharing options...
