darthdicky Posted August 21, 2018 Share Posted August 21, 2018 Is there any way easy way to test the speedo head and sensor without swapping them for new/second hand items? My speedo started to go a bit wobbly, then intermittent and now doesn’t move at all. Have taken the connector off the sensor and cleaned that up with WD40, it then worked for a little bit and stopped again. The cog looks fine in the bit that goes into transfer box so I don’t want to start replacing bits until I’ve proven where the fault is. Any suggestions? Is there a diagnostic mode on the speedo or am I being too hopeful! Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 21, 2018 Share Posted August 21, 2018 Cwazy Wabbit of this abode is the 'guru' for td5 speedo's, sounds like your transducer is having a crisis. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 22, 2018 Share Posted August 22, 2018 Looks like you're on the right path with the connector/sensor Dicky, if it started working again. Perhaps a minimal investment in a new 3 way female econoseal connector might prove fruitful ? HTH Mo Quote Link to comment Share on other sites More sharing options...
