ralph o Posted August 27, 2018 Share Posted August 27, 2018 Hello, Me again.Thanks for the help before. I am trying to replace the side trim on the tailgate/bodywork.(2003 freelander kalahari) They are held on with 3 clips that ,from what i have read need to be replaced whenever they are taken off. Mine are broken so have ordered new ones (3.99 ebay X 10 ) The trim has the 3 locations for the clips but 1 is the opposite to the other 2, it looks as though they should slide but i cant get them to fit. Any advise would be much appreciated Kind regards.. Ralpho Quote Link to comment Share on other sites More sharing options...
ralph o Posted August 31, 2018 Author Share Posted August 31, 2018 Arrha,,,, Sussed it.... Obvious when you know... But if you don't, you put the clips/fixing on the the trim and push on to the posts. They are sacrificial clips. Use once only . If you need to remove the trim, you will damage the clips beyond reuse and require new clips. This might be useful to someone Happy Freelanding!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
