New user new 2a owner
2a-Egg
17 minutes ago, lo-fi said:
Graphite grease is good for stuff that has a hard life in high temp. Best (I may have said before) is milk of magnesia, particularly on stainless.
You've definitely said it in a thread recently as I have read it
17 hours ago, Gazzar said:
Amazed by that. I'd have though too runny?
Yeah, you can't get big gobs of it on a thread like you can grease, but it coats well. Seems to be all you need.
Graphite, like copper, flashes off and you're left with the graphite. It's the weapon of choice on hotter parts of steam engines with steel studs in cast iron or bronze and can literally last decades.
Right so the truck is back together as sounds brilliant, starts better than before but is still over fueling. Im unsure if my carb is doing anything when I play with the mixture screw, what else (apart from timing maybe) would cause it to over fuel?
7 minutes ago, steve b said:
float level in carb. too high or float not floating any more , or needle not sealing correctly . The choke opens ok ?
You're getting several worthwhile jobs ticked off :i-m_so_happy:
cheers
Steve b
Yeah choke pulls fine. So possibly the float but I don't know what im looking at so wouldn't be able to say yes or no to that..
Trying to get stuff I can sensibly do myself done
Is the choke definitely releasing fully? The mixture screw on those carbs is just for idle, if I recall correctly.
Float height is usually set with the carb on the bench, float bowl off, upside down. You bend the little tab that pushes the float (fuel inlet) valve shut until the actual floaty bits are a specific height above a datum point listed in the rebuild manual.
Do you have an electric fuel pump? If so, are you running a regulator? Most pumps drive far more pressure than the poor little float valve can resist, so fuel gushes in even when it's closed. Same problem if the float valve is pitted or jammed and not fully closing.
Choke looks to be, thr the plate is vertical if I take the air intake hose off to look, can see the jet of fuel when I rev too.
Not had carb off or checked float, carb was replaced by previous owner, unsure if they just put it on or did any kind of setup with it.
Unsure if pump is electric, not looked into that and unsure what im looking at to be honest, will have to check manuals to know.
Electric would be an after market modification, the originals are mechanical and driven off the cam.
Might be worth popping the carb off and removing the float bowl to see what's what. The floats are just thin brass or plastic tanks and can crack or spring a leak, meaning they don't cut the incoming fuel off when it reaches the correct level. That'll lead to over fueling regardless of what you do with jets or mixture adjustments. Same goes for the little valve - could even just have some crud stuck in it.
Right im going with mechanical then as i can see anything that woild suggest an add on.
Never played about with a carb before. So this could be interesting.. I know the timing os a little off so might get that sorted, then look onto the carb..
Yes, get timing sorted first.
It may be that the internal o-ring on the carb is leaking, the new replacements you can buy are NOT made well, and very often leak from factory :(
To solve repeated issues with old and new carbs, I replaced it with an SU 😛 Bit more work than you probably want though :)
This evenings fun.. Only problem i have is the bulbs don't sit right, twist in then push back out too far, i have to push the side light bukb back in a little for it to come on.
May I have the wrong style bayonet? The at 12-6 and sit Right at the base of the metal.
Pic of the modification I had to make due to non round holes
Edited by 2a-Egg
