2a-Egg
New user new 2a owner
If it's running rich anyway, you'll find the evap problem easily makes it rich enough to refuse to start. The black schmoo is fairly typical, but doubtful it's causing the issue. When things in a carb get gummed up they tend to run lean, not rich. The float height we've been been talking about is fairly critical to proper function. In simple terms, there's a jet (very specifically sized hole) which connects the intake of the carb to the chamber with the fuel in. In front of this there's a venturi which creates an area of decreased pressure in the airflow right where the jet sits. Think of it as a circular wing. The jet is sized so that a specific amount of fuel is sucked up through the jet for any given pressure/rate of airflow. The jet is sat a distance above the nominal level of the fuel in the float chamber. If the level rises, its easier for fuel to be sucked through the jet as it has less far to be lifted. Too low a level has the opposite effect. The fuel level in the float bowl is set by the float, which works exactly the same as the ballcock in a toilet or water tank. Setting it correctly ensures the correct fuel level and correct fueling. A worn jet (yes, the fuel does eventually wear them out and enlarge the hole) can also cause problems. So can a leaky diaphragm in the accelerator pump, so can a leaking gasket, so can a broken float, so can a pitted float valve etc etc...
With the carb on the bench and a rebuild kit ready you can cover all those bases and be pretty confident it'll work correctly when you reinstall it.
Share this post
Link to post
@lo-fi thanks for all that information, will come in handy.
Next thing, what oil do people use in their air filters?? I never changed mine when I cleaned it as didn't have any. So 15/40?
Share this post
Link to post
Engine oil.  Don't use "heavy oils" like transmission oil as it's too thick and won't splash about the gauze while driving.  The idea of the filter is that the gauze is wet for dust to stick to it, but not submerged as you'll get oil ingestion or just a restriction to the air.  As the oil sloshes around in the casing from bumps, cornering and braking, it splashes up the the gauze and cleans off the accumulated dirt and also re-wets it.  Its essentially self-cleaning, and in that respect, far better than paper filters.  But the oil needs to be thin enough to splash and run easily.  If you don't have oil, then diesel or kerosene would probably do.
Share this post
Link to post
Well my luck with the sump gasket change has run out. Oil coming out the rear on the sump, I might of made that out of my own doing, by possibly putting to much oil in as it was on low so topped it up but now its sat on or slightly above high. Will clean it all off and then check the bolts haven't worked loose
Share this post
Link to post
So the oil is coming out of the rear corner of the sump or looks that way, the runs down to the plug and drips. Is this just where it hasn't sealed properly or is there potential of the krankshaft being a bit drippy?
Share this post
Link to post
I've learnt more about the SIIa in this thread than my entire life owning Landies.
Love it :D
  • Thanks 1
Share this post
Link to post
Love it :D
Ha, happy that my tinkering and others replying has helped..
Share this post
Link to post
Right.
I have replaced the sump seal, and i still have oil leaking from the back of the sump, where it meets the gearbox.. Have i got a possible inner rear crank shaft leak???
Share this post
Link to post
Very possible I'm afraid, it is gearbox or engine out time if you need/want to fix it.
If it is not that much, just live with it ;)
  • Sad 1
Share this post
Link to post
If its the T piece cork, is that engine out is it.?? Rubbish.
Share this post
Link to post
The T seal is between the rear main bearing cap and the block then outside that on the back of the block is the rear main seal , a two piece ring with the seal moulded to it , if you are doing one I'd do both , and yes it is engine out to make it easier to work on .
I'm  no fan of fixes in a bottle but there are seal swelling additives on the market which may slow it down for a while .
It would be the same engine out/box off for any other engine with a rear crank leak , of course while it's out it is the ideal opportunity to paint the block etc.
cheers
Steve b
  • Thanks 1
Share this post
Link to post
You can see on the image of back of sump where oil is, which is leading mento the crack seal. The leak only occurred after i toppes up the oil and after a few miles journey, sat after the work was completed with oil in, no leak occured.
Also is it me or does the large bronze stop not look flush in the other image?
Share this post
Link to post
On 5/11/2019 at 1:39 PM, 2a-Egg said:
Anyone know what they call the bronze plug... Online I can only find fuel tank plug, but that isn't the fuel tank!!
Share this post
Link to post
Transfer box drain plug.
Go to foundry 4x4 for a magnetic version. See my lightweight rebuild thread for details.
Share this post
Link to post
Your plug looks completely diff to mine, so I'm guessing previous owner put wrong one on then ha
Share this post
Link to post
No, yours is correct, mine is a new after market design that has a magnet in it. The magnet captures metal/steel shards in the oil, and stops them from doing further damage.
You need part 235592 and the associated washer (genuine).
Share this post
Link to post
Tool?
Use a spanner. Put the spanner side in the slot!
Remember these series were designed to be serviced with a basic toolkit.
Share this post
Link to post
2 hours ago, Gazzar said:
Tool?
Yeah I know, just funny how you search for that part number and then brings the tool up too
Share this post
Link to post
Yes, there's always something to learn.
Share this post
Link to post
Well it seems that I need to get it up in the air and a lot of seals replacing haHa. Transfer box for definite, then there is oil coming out of front drive shaft where it meets the gearbox. Think it just needs incontinence pads on the ground
Share this post
Link to post
Be ready to repair the seal land at the same time.
Share this post
Link to post
Think I have just accepted that there is more to do than first thought. Haha. But it's a runner and solid
Share this post
Link to post
