nearlyretired Posted September 6, 2018 Share Posted September 6, 2018 Hi, Just joined this site cos it looked very professional and there seems to be a lot of knowledgeable people here (creeping). I have just bought a 1990 110 defender and I need to fit a 12s socket for my caravan towing. My question is, is the wiring required already at the back or do I need to bring the power cable from the front. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Giles Posted September 7, 2018 Share Posted September 7, 2018 Hi, you can pick up all the wiring by removing the screwed in cover tucked into the corner on the rhs of the back door - there are (should be) spare connectors for all rear lights there. What you'll actually find depends on who's been in there before... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 7, 2018 Share Posted September 7, 2018 12S is the power feed for the fridge, fog and reversing light. I suspect the question is mainly about whether there is a suitable 12V at the back of the vehicle or if you have to run a switched fused one from the battery....? I don't know that answer though, not on a defender. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 7, 2018 Share Posted September 7, 2018 You may be able to use the rear wiper or heated window supply if one or the other isn't fitted. But this may require a relay fitting in place of the switch in the dash. If these are in use then it's a new cable I'm afraid. Mike Quote Link to comment Share on other sites More sharing options...
western Posted September 7, 2018 Share Posted September 7, 2018 Easier to start from nothing & run new wires from battery bay to rear, along top of left chassis rail would be a safe outing to rear end. the split charge/fridge relays can be sited in battery bay as well. [if there's enough space for them] Quote Link to comment Share on other sites More sharing options...
nearlyretired Posted September 12, 2018 Author Share Posted September 12, 2018 Hey guys. Really appreciate the replies. I think it might be easier as Western says and to start from new and run my own wires in from the battery and putting the relays in the battery compartment. As for Miketomcat's suggestion re rear wiper/heated window, they are both in use, another reason to start afresh. Thanks again Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 12, 2018 Share Posted September 12, 2018 You might find it easier to use a multicore cable than build a harness for the run along the chassis. Quote Link to comment Share on other sites More sharing options...
western Posted September 12, 2018 Share Posted September 12, 2018 You can buy multicore cable by the metre [grey outer cover] for the 12S wiring on vehicle & trailer. Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted September 13, 2018 Share Posted September 13, 2018 Interesting. Id always thought that there was a live feed to the rear of the chassis? (Im sure I saw it on here somewhere) I had planned to use it for some project that has yet to materialise! Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2018 Share Posted September 13, 2018 there is a plain purple permanent live 12v feed to the right rear corner, don't think its a fused wire Quote Link to comment Share on other sites More sharing options...
