Handbrake lever TD5 vs 300tdi
Dan D90
Does anyone knows if there is any difference between the TD5 handbrake lever and the 300tdi??
My handbrake seems to be seized, I was going to replace it with an x brake so I have purchased the bracket which sits behind the handbrake lever and holds the cable, which apparently is needed.
It might be a while before I can afford the x brake so I thought I would take another look at the current setup.
It seems the brake cables on the TD5 and 300tdi are a little different.
The TD5 cable seems to sit directly into the handbrake lever, whereas the 300tdi is threaded and screws into the bracket
Without the bracket attached the 300tdi cable is a sloppy fit:
Are there different handbrake levers for the TD5 & 300tdi?
The 300tdi cable also seems to be a bit longer:
Thanks Dan
