MR-HIPPO Posted September 13, 2018 Share Posted September 13, 2018 The 300tdi defender main loom to engine loom has two plugs, a large multi plug, and a single round plug that carries the feed from the starter relay to the immobiliser. The engine loom side of the small plug is connector no C203. C203 is attached to a metal clip, I am trying to identify the clip. One end of the clip is a spade type tab with a square hole, and the other end has a bolt hole. I need to panel mount a 300tdi engine compartment fuse box, and it looks like two of these clips will do the job just fine. Thanks in advance Hippo Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted October 19, 2018 Share Posted October 19, 2018 On 9/13/2018 at 8:19 PM, MR-HIPPO said: The 300tdi defender main loom to engine loom has two plugs, a large multi plug, and a single round plug that carries the feed from the starter relay to the immobiliser. The engine loom side of the small plug is connector no C203. C203 is attached to a metal clip, I am trying to identify the clip. One end of the clip is a spade type tab with a square hole, and the other end has a bolt hole. I need to panel mount a 300tdi engine compartment fuse box, and it looks like two of these clips will do the job just fine. Thanks in advance Hippo It might be 20 or 21 on this link? https://www.landroverworkshop.com/diagrams/engine/300tdi/cylinder-head_53178#21 Quote Link to comment Share on other sites More sharing options...
