14Platoon Posted October 17, 2018 Author Share Posted October 17, 2018 4 hours ago, Mo Murphy said: See, the Land Rover is starting to make a mechanic of you 😁 Mo Ha already done quite a bit, I’ve had classics of all sorts for years, just not done this before. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 17, 2018 Author Share Posted October 17, 2018 2 hours ago, western said: did it run ? Got called in to work, should be able to try it on Friday👍🏻 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted October 17, 2018 Author Share Posted October 17, 2018 4 hours ago, Mo Murphy said: See, the Land Rover is starting to make a mechanic of you 😁 Mo My other classic keeping me busy. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 18, 2018 Share Posted October 18, 2018 👍Nice. Mo Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2018 Author Share Posted November 2, 2018 Where can i connect a battery to test this unit. I’m testing the motor separate from the switch. Any ideas if I can connect a car battery, if so to which wires on the blower unit. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2018 Share Posted November 2, 2018 Thought I had replied to this on page 3 of this thread you asked about which wire does what a few weeks ago. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 2, 2018 Share Posted November 2, 2018 Purple/Green +12V power. Green/Slate and Green/Yellow ground. One high speed, the other low speed. 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2018 Author Share Posted November 2, 2018 3 hours ago, western said: Thought I had replied to this on page 3 of this thread you asked about which wire does what a few weeks ago. I thought you referred to wires in the switch component, I couldn’t find a black one on the blower unit itself when it was off the vehicle. I thought I’d best check before giving myself a little shock. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 2, 2018 Author Share Posted November 2, 2018 I’ll give this a go in the morning, been very busy this month. 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2018 Share Posted November 2, 2018 1 hour ago, 14Platoon said: I thought you referred to wires in the switch component, I couldn’t find a black one on the blower unit itself when it was off the vehicle. I thought I’d best check before giving myself a little shock. same color wires from switch to motor, but plain black is earth at switch only, Red90's info should get the motor powered & running. 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 4, 2018 Author Share Posted November 4, 2018 I put wire direct from the battery, positive to the purple wire on the blower unit, simultaneously I put a wire direct from the battery earth to the green and slate wire on the blower unit........nothing happened! Do I take it that the motor is Fubar? Thanks Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 7, 2018 Author Share Posted November 7, 2018 Thanks for your help guys. The blower motor was knackered, new one works straight away on the Hotwire test. Thanks for the advice, saved a lot of messing around and the purchase of a resistor. Just got to fit all the cables back in now, oh and those 2 nightmare 13mm bolts🙄 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 8, 2018 Author Share Posted November 8, 2018 Just a quick one..... The switch on the dash (lever and cable) to turn the fan on, where does this cable go, on the side or the top of the blower box? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 8, 2018 Share Posted November 8, 2018 Side 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 8, 2018 Author Share Posted November 8, 2018 4 minutes ago, Red90 said: Side Nice one 👍🏻 Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2018 Share Posted November 8, 2018 48 minutes ago, 14Platoon said: Just a quick one..... The switch on the dash (lever and cable) to turn the fan on, where does this cable go, on the side or the top of the blower box? have a read of my post called feeling cold in your truck, it gives you info on how to set up the cables. 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 9, 2018 Author Share Posted November 9, 2018 All done everything back in 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 10, 2018 Author Share Posted November 10, 2018 Hmmm it blows really well and gets warmish. I seem to remember it being warmer before, although I only did a 10 min journey but the temp gauge was halfway. Is this normal? Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2018 Share Posted November 11, 2018 Maybe a airlock as you've had the matrix out. 1 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted November 11, 2018 Author Share Posted November 11, 2018 2 hours ago, western said: Maybe a airlock as you've had the matrix out. Hmmm yes that would make sense. Quote Link to comment Share on other sites More sharing options...
