Kurt Posted September 16, 2018 Share Posted September 16, 2018 Wondering if anybody has any experience of using it on the engine facing side of the bonnet and will it be ok? It is the hard protective wax 4941im intending on using. On the can it says it is resistant to spray painting oven temps. Quote Link to comment Share on other sites More sharing options...
joe1 Posted September 16, 2018 Share Posted September 16, 2018 I havent used that product but bake mode ovens go to around 80degC. Your bonnet probably wont be that hot - but there may be areas of high heat eg around the top of the radiator and above the exhaust - and heat will rise, so there may be localised spots that aren't far off that value. Also consider a really hot day with baking sun - the bonnet may well get too hot to touch, but your wax will be on the cooler underside of the panel so might not be too bad. Give it a go! 1 Quote Link to comment Share on other sites More sharing options...
