MR-HIPPO Posted September 16, 2018 Share Posted September 16, 2018 I need to install intrusion switches and central locking actuators for 2nd row doors in my 1989 CSW project. What is the standard route to get a wiring harness into the B-pillars of a 110 station wagon? Many thanks Hippo Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 25, 2018 Share Posted September 25, 2018 (edited) I don’t have central locking but I do have door switches and the harness is plugged into the front where it leaves the top of the A pillar at the rh side and is simply taped to the roof and the single core drops down the respective B pillar to the switches. The headlining hides the lack of finesse. Edited September 25, 2018 by Peaklander 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 25, 2018 Share Posted September 25, 2018 I don't have the central locking ( yet) either but I notice YRM do 2 versions of the second row kick panel, one for central locking. So I deduce the cables run along the top of that panel/seatbox 1 Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted September 26, 2018 Author Share Posted September 26, 2018 Thanks Guys. I have been looking at the electrical libraries for a 97 300tdi, and a td5 trying to figure this out. The 300tdi loom runs along the roof as described above, and the TD5 central locking harness comes up out of a grommet in the top edge of the kick panel. I have been unable to figure out the route that the 300tdi door pillar switch wire takes from the roof loom to the switch in the pillar. Does it run underneath the pillar trim, or does it drop through a hole in the roof (that I do not have) into the top of the pillar? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 26, 2018 Share Posted September 26, 2018 The wire goes in at the top, between pillar top and roof where there is a foam seal. It then drops down within the pillar itself and the door switch pokes into that space lower down. So to make the connection you have to hook the spade at the end of the wire and pull it out to be able to push it onto the switch contact which is then pushed back into the pillar and the switch is fixed with a self tapper which is the connection to ground (0 volts). 1 Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted September 26, 2018 Author Share Posted September 26, 2018 Thank you for the explanation. I have the older type external rubber seal, so no foam. But it does look as though there is room for a cable to pass between the roof and the inner corners of the B pillars. Quote Link to comment Share on other sites More sharing options...
