Samson Posted September 22, 2018 Share Posted September 22, 2018 Hi Im trying to assamble a 1977 LR 2.24 diesel series 3 and it is going well. Until now! Yesterday I powered it up and the starter was a bit slow and did not get going. I connected an extern power and suddenly when I pushed the starter button I’ve got smoke from the short speed cable as it was heating up. I disconnected it and then the diesel pump stop cable melted. The starter solinoid was clicking but the starter did not turn. Today I took of the starter and cleaned it all up and got it spinning and the solinoid to move fine. Put i back on and it was clicking again but did turn with my brand new (very expensive!) battery. Anyone got any ideas why the cables Connected to the diesel pump are heating up when I push the starter button? Hope to hear from you guys! Quote Link to comment Share on other sites More sharing options...
western Posted September 22, 2018 Share Posted September 22, 2018 You need a thick earth cable from engine block to chassis, yours is using those 2 routes to provide a earth path for the electrics, you'll end up with a burnt out truck. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 22, 2018 Share Posted September 22, 2018 As Ralph says it sounds very much like a poor earth. Test by running a jump lead from clean metal somewhere on the engine block to a bit of clean metal on the chassis. Quote Link to comment Share on other sites More sharing options...
steve b Posted September 22, 2018 Share Posted September 22, 2018 welcome to the forum , always good to hear of another series being preserved . As above your engine to chassis earth is missing - the std. one is bare thick plaited copper strands and goes between the starter mounting bolt across to the outrigger angle iron brace , 10mm eye at starter and 8mm eye to angle , around 300mm long . cheers Steve b Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 22, 2018 Share Posted September 22, 2018 As all the above have said. Classic symptoms of a poor or missing earth. jon Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 24, 2018 Share Posted September 24, 2018 What they said. You can prove it by using jump-leads from battery -ve to the engine block. Quote Link to comment Share on other sites More sharing options...
Samson Posted September 25, 2018 Author Share Posted September 25, 2018 Hi Guys! Thank you so much for your expertise and advise!! Will connect a huge earth cable from engine to chassis and try again!! All the best from Copenhagen to you! 1 Quote Link to comment Share on other sites More sharing options...
