Mutley Posted September 27, 2018 Share Posted September 27, 2018 I aquired this tool a couple of years ago, second hand with no instructions. Now i managed to figure how to put the correct rivnut setter on, and so opened the arms and screwed on the rivnut as far as it would go, then inserted the rivnut into the reqired hole and proceeded to squeeze the arms together. Well they moved in a fraction but then i couldn't move them any further. After jamming one of the arms into my stomach and using both hands, gave it some major pull!?! Load crack and the arms came togerher, great i thought only to find the rivnut had its thread stripped? So what am i doing wrong and how do you use these thing please??? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 27, 2018 Share Posted September 27, 2018 Perhaps show pictures of how it is assembled and what you are doing. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 27, 2018 Share Posted September 27, 2018 What Red90 said! Also makes a difference if you were using M3 rivnuts or M10's as to what could be going wrong - small ones are not much harder than a rivet to put in, big ones can be utter barstewards. Quote Link to comment Share on other sites More sharing options...
Mutley Posted September 27, 2018 Author Share Posted September 27, 2018 At work till late but photo is similar model except colour..... Trying to put an M6 rivnut insert in the rear cross member of a defender 90 to hold mud flap brackets. I know photo shows tool with rivet attachment but have managed to put the M6 rivnut mandrel on..... Do you screw the rivnut insert on all the way as foar as it will go? Then push into the hole and squeeze the arms together? Or is there a knack to putting the nut insert on the tool to start with??? Quote Link to comment Share on other sites More sharing options...
dave88sw Posted September 27, 2018 Share Posted September 27, 2018 I've got the same one, there's no real instruction as to how far you screw it onto the rivnut, only how to assemble the tool. It's a bit of guesswork really, i basically look at the rivnut and estimate how long the section that collapses is (the bit between the thread and the flange), then with the arms of the tool together, screw the rivnut on until it stops, open the arms and then screw the rivnut on the length you estimated, insert the rivnut in the hole and squeeze the arms together with a reasonable force or until they touch without going overboard. Then unscrew the tool and check it's reasonably tightly set in the hole. As long as it isn't loose enough to rotate as you thread a bolt in it should be fine, it will pinch up when you tighten the bolt. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 27, 2018 Share Posted September 27, 2018 Perhaps after it moved a touch, it was actually done, and just much easier than you thought it would be? Then you went all David Banner on it and tore a new hole in the rivnut Quote Link to comment Share on other sites More sharing options...
Mutley Posted September 27, 2018 Author Share Posted September 27, 2018 Thanks dave88sw did it your way and a lot better result, and there does seem to be a bit of guess work for the 1st. Stage of screwing on the rivnut with the arms closed!?! @Bowie69 tooktook me 2 seconds to twig the David Banner gag lol. Think i was more up set that it took that long to register who he is rather than the fact that i am old enough to remember who he is lol Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted September 27, 2018 Share Posted September 27, 2018 You may need to practice a bit with material of a similar thickness. Once the rivnut is set, any additional pulling simply damages the rivnut. The hassle is, if they aren't squeezed enough they will spin, but if you pull too much you mess them up.. Generally, you can feel the rivnut "give" as it deforms to the final dimension before it becomes harder to pull and you enter the damage phase of setting it. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 28, 2018 Share Posted September 28, 2018 I've had the same tool for a number of years and have used it a fair bit. Good, quick tool but difficult to use in a confined space. I set mine up in pretty much the same way as dave88sw suggests, if you don't, and are not used to how it feels when the rivnut has set, it's easy to overcook the force and collapse the thing too far. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted September 29, 2018 Share Posted September 29, 2018 I practised a bit with some metal I could see both sides of. Quote Link to comment Share on other sites More sharing options...
