Cchase Posted September 30, 2018 Share Posted September 30, 2018 I am going to convert my 'arm-strong' 12J 2.5 NA to power steering, if possible. It is a bit of a bear to maneuver at low speeds in the woods and I am not getting any younger. I know that some of you purists will scoff, so scoff away! The truck is a LHD 1995 ex MOD with am MA serial number. I have tried to source a used PAS system from a Discovery, but there is not much to pick from on this side of the Atlantic and their condition is sketchy at best. If anyone has photos of a 12J engine with power steering, I would appreciate seeing them. From the information that I have been able to get on this forum, I will need a NTC9070 pump and the NTC1581NOR steering box (this is Paddock's number). I have the bracket to hold the pump to the side of the engine. Also I have found the part number for the pulley for the pump - ETC5783. What other bits will I need? Any parts numbers would be appreciated. In particular puctures or part numbers for the three hoses that I will need. I can see the parts on this page for the hoses and reservoir, but the page does not give part numbers. https://allbrit.de/epc.cfm?PAGE=P01010&CAR=L1&SPRACHE=EN#4 Thanks, Colin Quote Link to comment Share on other sites More sharing options...
14Platoon Posted September 30, 2018 Share Posted September 30, 2018 I have an ex MOD 1992 Defender. I called Craddock spares and they supplied everything. I got my local garage to fit it (really cheap). As for originality, this was actually an option back in the day so it's still original. FYI it's sooooooo much better with power steering. 1 Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2018 Share Posted September 30, 2018 You will need a 2 belt crank pulley as well, to enable the engine to drive the PAS pump. all the part numbers should be in here http://www.retroanaconda.com/landrover/2009/12/land-rover-defender-90-parts-book/ within the appropriate engine section & steering section. 1 Quote Link to comment Share on other sites More sharing options...
Cchase Posted September 30, 2018 Author Share Posted September 30, 2018 Thanks, folks. There are two empty pulley 'slots' on the crankshaft so I think that I am safe there. One was probably for the 24V alternator. Don't usually use Craddocks as their online platform has few/no pictures. Will check prices once I have the part numbers. Cheers, Colin 1 Quote Link to comment Share on other sites More sharing options...
Cchase Posted October 1, 2018 Author Share Posted October 1, 2018 Thanks, Western. That gave me the numbers that I needed. The order has been placed. My shoulders feel better already! C Quote Link to comment Share on other sites More sharing options...
western Posted October 1, 2018 Share Posted October 1, 2018 on your 3 groove crank pulley the front groove is for the PAS pump belt, same as my 200tdi. 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted October 1, 2018 Share Posted October 1, 2018 10 minutes ago, western said: same as my 200tdi. Ralph, are those photos above before or after the rebuild? I only ask because of those great photos of a pristine looking 200tdi once you had rebuilt it, unsullied by road grime 🙂 Quote Link to comment Share on other sites More sharing options...
western Posted October 1, 2018 Share Posted October 1, 2018 the photo's above were taken in Nov 2006 well before I did the rebuild. Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 Thanks, Western. That gave me the numbers that I needed. The order has been placed. My shoulders feel better already! C Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 Here are some shots of the conversion should anyone else want to convert to PAS. First shot is the bracket for the pump. The Alternator fits on top. Second shot is the comparison between the old 'armstrong' box and the new box. Third shot is the location on the frame where the new box will go. C Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 Here is the new box in place. C Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 The PAS pump. NTC9070. with pulley attached. Do this before attaching the pump to the bracket unless you are a masochist! I had to drill new holes in the pump mounting plate in order to 'clock' the pump 45 degrees. Otherwise the hoses would be either blocked by the pump mounting bracket or the frame. C Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 The flange that attached the steering box to the tie bar is thinner than the one on the manual box and I was too cheap to get shorter bolts, again. The reservoir mounting bracket is home made as I could not justify £58 for the proper bracket. Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 9, 2018 Author Share Posted November 9, 2018 Final installation with alternator in place. PAS Belt ETC5815 (Dayco 13A0725C) was too short so I used NAPA belt 7280 which is a narrower belt and works just fine. The shiny coating is Rust Check undercoating as this all will get muddy soon. I'll take the drop arm from the old steering box to have as a spare. Cheers, Colin 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 9, 2018 Share Posted November 9, 2018 Colin, that is all so shiny. Good job and one for the tech archive 👍 Mo Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 9, 2018 Share Posted November 9, 2018 With a LHD, it is easier to put the reservoir on the left side. The pipe runs then end up being really short. It helps a lot in keeping it working at arctic temperatures. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 9, 2018 Share Posted November 9, 2018 Oh, and on the belt. You are going to want to go back to the 13 mm belt or you will burn it out. The 725mm or 28.5" will fit. You just need to lever it on there. Dayco 17285. Quote Link to comment Share on other sites More sharing options...
monkie Posted November 9, 2018 Share Posted November 9, 2018 Looks great. Good work Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 10, 2018 Author Share Posted November 10, 2018 17 hours ago, Red90 said: With a LHD, it is easier to put the reservoir on the left side. The pipe runs then end up being really short. It helps a lot in keeping it working at arctic temperatures. Red 90, The truck enjoys a restful winter as the salt storms on NS highways are pretty intense. I have a raised air intake on the LHS so space is at a premium there. In retrospect and given the price and quality of the hoses, I would have custom hoses made next time. The short hose from the box to the pump would not attach to the pump as the threads on the connector would not reach the female threads on the pump. I had to have a new connector put on the hose. I have contacted the supplier and am waiting to see if I get any response. C Quote Link to comment Share on other sites More sharing options...
fullthrottl6 Posted August 16, 2019 Share Posted August 16, 2019 Hi guys, I'm planning on undertaking the same work on my 2.5na Ex Mod 90. However, I only have the 2 groove pulley, with the second groove free. Can I use the second groove to for the power steering, or does it have to be a 3 belt pulley? Cheers! Dan Quote Link to comment Share on other sites More sharing options...
western Posted August 16, 2019 Share Posted August 16, 2019 Only need a 3 groove pulley if air con is fitted. Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 16, 2019 Share Posted August 16, 2019 Looks very, very nice ! Well done Sir. "... as this all will get muddy soon ..." Very true. For this, and more space, we moved the alternator on the 200 Tdi to the Airco pump position on top of the engine to make it less of a target for mud and all the rest.. Quote Link to comment Share on other sites More sharing options...
fullthrottl6 Posted August 16, 2019 Share Posted August 16, 2019 1 hour ago, western said: Only need a 3 groove pulley if air con is fitted. Ok thanks, but will the pulley line up ok with pump? Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 16, 2019 Share Posted August 16, 2019 It should, but if not, add washers between the flat plate of the pump mounting and the cast iron cradle to move the pump forward, or between that plate and the pump body to move it aft. Quote Link to comment Share on other sites More sharing options...
Gabby1971 Posted August 9, 2023 Share Posted August 9, 2023 On 10/1/2018 at 9:15 AM, western said: on your 3 groove crank pulley the front groove is for the PAS pump belt, same as my 200tdi. Hi this is a great thread. Really helpful. We have just bought a landrover 110 camper, based on 1994 military defender 110 (Tithonus) NA 2.5 ltd diesel. It a lovely Landy.. What we want to do is put power steering in asap to save the aches and pains of driving as is. So reading the previous messages would you advise ringing Craddock's and Paddocks for the parts listed in this thread? Could do with a listed breakdown of what exactly needs to be bought and fitted. Feel like such a newbie. Also how much did it cost for the parts in total? Thanks for any help... Quote Link to comment Share on other sites More sharing options...
