TD5 fuel economy
  • 3 months later...
Quick update for anyone else thinking of doing this conversion.
Finally got the  Disco TB fitted last week and at the same time replaced a seized rear prop. Also replaced the straight through exhaust fitted by the PO with the original centre box as it caused a pretty mind numbing drone at motorway speeds. Vehicle now drives and sounds much better with little effect on performance due to the increased gearing. You can tell it’s been geared up but not to the extent that it affects drivability. Engine revs have dropped and the cab is a much nicer place to be 👍
