Perrrrr Posted October 3, 2018 Share Posted October 3, 2018 Hi Got a cv-joint problem. The numbers on the axle are gone. My car is a series with defender? Axles, might be disco or rrc. The car was bulit in 1995. I got no info about the build. The car has the 19j engine, lt77, disc in rear, platic cap on drivemember in front, onepiece axle and drive member in the back Bought the cv-kit from paddock which fits defender from Defender 1986 upto KA930455 non ABS with 32 internal splines. This cv is to long, ca 2cm to long on the drive member side. The spline count is ok. Anyone got hints? Per Bakkejord Norway Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 3, 2018 Share Posted October 3, 2018 It's probably a later axle with the narrower hubs and therefore shorter stub axles and CVs. Have you got a picture of the outside of the hub? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 3, 2018 Share Posted October 3, 2018 Have a look for the axle number on the top of the long side of the case. That's how I was able to track down the origins of my replacement rear axle. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted October 3, 2018 Share Posted October 3, 2018 (edited) 2 hours ago, landroversforever said: Have a look for the axle number on the top of the long side of the case. That's how I was able to track down the origins of my replacement rear axle. He already stated the axle number is missing. You can tell by the drive flange. Show us the drive flange. As above, sounds like a late model axle (1994+). Short 32/24 CV joints, part number TDJ000010. Edited October 3, 2018 by Red90 Quote Link to comment Share on other sites More sharing options...
