Bit of a bench in the making
Blanco
As it was a pleasant afternoon, got the bandsaw fired up to clean up the sleepers I had aquired to make a bench top, ..... yes it is a tad on the substantial side.
Toasted two blades, sleepers are full of unfriendly grit etc. which is almost impossible to remove.
Nice
But please note the obvious : the are regarded as chemical waste and working in the industry, we treat them as such..
The dust etc. is not good.
But once in place, they will do just fine !
Love your mobile sawmachine..
Rules seem a bit behind over here, already in France (3 years ago for me)  they were very difficult to get hold of, a shame as most were oak not softwood. These are all softwood and one is full of old fashioned creosote.
I have milled the French oak sleepers with the bandsaw with very little trouble, perhaps the grit sticks in the grain of the softwood more easily? When the big mill goes (which it will this Winter) I thought I might go for an Alaskan if I needed to do another timber frame ever. Slower but probably more flexible.
Italy replaced 100's kms. of oak sleepers in the late '90's on the HSL's for concrete and the Continental market was floaded with them.
Very good quality - some less than a year old...
These days, nobody wants them..
Ah but I think they are tropical hardwood with no preservative treatment. Used to be a company called Jarrah Design or Jarrah Furniture in the North west of England did some nice pieces, don't know if they are still about. I'll have to look them up.
Most of the sleepers we had were Jarrah and Karri, some Oak from the early days, apparently.
14 hours ago, Blanco said:
Was the Jarrah imported I wonder or did/does SA have a native species?
It is an invasive import form Australia. We have Eucalyptus, Black Wattle and Port Jackson Willow which are varying degrees of nuisance, depending where you live.
We have Port Jackson in the Western Cape that regularly contributes to the big fires we have when our local Fynbos does it's regeneration burn.
On the other hand, Eucalyptus in the fireplace really gives a good burn, plus, my wife's lungs don't mind it as opposed to Port Jackson which has her wheezing in short order.
I remember hearing as a kid that sleepers were Rhodesian Teak, but that was phased out in favour of the locally grown Jarrah.
  • 5 weeks later...
Just back on this a bit today, ..... no pics but just fixing it to the floor and wall. As this is the 'engineering' bench I thought I might put a steel top on part or all of it, just wondering what people have used to good effect?  Thinking thickness wise,................ strength isn't the issue so much as dent resistance............. and would it be worth the extra for SS?
I wouldn't use SS , it will hold every bit of spatter from welding , a thin sheet of Hardox or AXR ~ 3 or 4mm would be dent resistant or 6mm S275 steel .
wandering off a bit , what model no HIAB do you have on your trailer ? I have one very similar cobbled onto the Yard Hicap with no model type or proper rating plate
cheers
Steve b
Steve, thanks for the feedback on steel, I hadn't thought about weld spatter, good point.
The Hiab (my one) is an 022T, (2.2Tm), I can take a snap of the plate if you want tomorrow, there is also a very similar, visually near identical 017 which I have the handbook for (It was available at the time, the correct one wasn't), I have also seen 025 and 027. The T signifies the simplified boom format, ie post and telescopic main boom, no dipper.
A pic or two of the crane and plate would be great ta . It sounds like mine is the same or similar , they lift really well .
...mind you a dipper and another slide out or two would be good :) , Hyva make a rather nice unit for 3.5T LGV's but it is pricey
cheers
Steve b
cheers
Steve b
Why would the stainless hold the spatter more than variants of mild? :unsure:
  I can't give you the scientific reason Ross , but experience of production MIG welding stainless with an 3ph. transformer unit has shown that any spatter will very firmly attach itself to SS particularly any polished/cleaned area , even with copious anti-spatter spray . TIG is sooo much neater but sooo much slower for production work .
Thanks for the pic's Blanco , mine has one powered slide out and a pinned fixed extension but otherwise looks the same with a max reach of 2.5m
cheers
Steve b
Edited by steve b
reply to Blanco
cheers
Steve b
Interesting! One of my jobs at some point is a metal top on the workbench. Maybe mind is a better way to go (only trouble being rusting between uses. Having said that I am planning a welding back at some point.
