Michael B Posted December 20, 2006 Share Posted December 20, 2006 Maybe someone out there can help with a little (but worrying) problem. The tachometer on my 89 won't read correctly. Sometimes it doesn't pick up, sometimes it fluctuates wildly but sometimes it works. I know a failing tach is a sign of a bad alternator but i've just had my alternator replaced. can anyone give me some advice? Thanks! Quote Link to comment Share on other sites More sharing options...
neilwilson Posted December 20, 2006 Share Posted December 20, 2006 B)--> QUOTE(Michael B @ Dec 20 2006, 02:14 AM) <{POST_SNAPBACK}> Maybe someone out there can help with a little (but worrying) problem. The tachometer on my 89 won't read correctly. Sometimes it doesn't pick up, sometimes it fluctuates wildly but sometimes it works. I know a failing tach is a sign of a bad alternator but i've just had my alternator replaced. can anyone give me some advice? Thanks! If it is anything like the Discovery 300TDi alternator connectors, then there will be a single wire on a spade connector at the back of the alternator that often works loose. You can take it off, clean up the contacts & push it back on. Some people say to use a new connector but that depends on how worn it is and if just reseating works for you, a mild squeeze with pliers can also help the connector hold. Neil Quote Link to comment Share on other sites More sharing options...
