Shaysdad Posted October 8, 2018 Share Posted October 8, 2018 Hiya, Coolant is pouring out from around the bottom-most belt wheel (see image attached) on Freelander 1.8 petrol 2000 K Series. Empties coolant expansion tank in seconds. Any advice, including crushing, most welcomed! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 9, 2018 Share Posted October 9, 2018 It's been a while but is the water pump driven from the cambelt and therefore leaking into the cambelt cover and pouring out of the bottom? Are you sure it's coming from the pulley hole or is it running down from further up? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 9, 2018 Share Posted October 9, 2018 Must be the water pump : Quote Link to comment Share on other sites More sharing options...
Shaysdad Posted October 9, 2018 Author Share Posted October 9, 2018 Thanks for replies guys. Have taken off belky pan and now cam cover. Looks dry in cam belt housing, but it does appear to be coming from a little higher up than pulley hole. Going to go the water pump route and hope for tbe best! Quote Link to comment Share on other sites More sharing options...
