nenook Posted October 14, 2018 Share Posted October 14, 2018 Good evening, ive just come back from recovering my mate with his v8 d2 auto ,it’s overheating big style , and it’s blowing cold air through the heater when on full blast set on hot , is it common on these ? At first I though head gasket but there’s cross contamination. Any help greatfully received thank you Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted October 17, 2018 Share Posted October 17, 2018 Head Gaskets are a common fault with V8's I am guessing it is a 3.9 so it could be head Gasket or dropped cylinder liners. Try a block sealand first before you take the haeds off. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 18, 2018 Share Posted October 18, 2018 Dropped liner is a bit over-dramatic isn't it? If it's a D2 it'll be a 4.0, I can't remember the exact plumbing of those but check the easy & cheap stuff first - is it pressurising the cooling system / oil in the water (head gasket) or maybe the thermostat is dead/stuck (cheap & easy fix). Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 18, 2018 Share Posted October 18, 2018 2 hours ago, FridgeFreezer said: Dropped liner is a bit over-dramatic isn't it? If it's a D2 it'll be a 4.0, I can't remember the exact plumbing of those but check the easy & cheap stuff first - is it pressurising the cooling system / oil in the water (head gasket) or maybe the thermostat is dead/stuck (cheap & easy fix). Probably not,the poor quality of the 94mm bore Rover V8's has led to many P38's and DII's being scrapped well before their time. Loose liners or cracked blocks were all too common.A real shame because I lost too many customers who lost large sums when their v8 died. The engine should not have been bored out like they did,it needed a larger block with wider bore centres . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 18, 2018 Share Posted October 18, 2018 Oh I know their reputation, I mean the leap from "it's overheating" to "dropped liner", FFS there's some basic diagnostics before anyone need make proclamations of doom. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 19, 2018 Share Posted October 19, 2018 20 hours ago, FridgeFreezer said: Oh I know their reputation, I mean the leap from "it's overheating" to "dropped liner", FFS there's some basic diagnostics before anyone need make proclamations of doom. Absolutely, and its the diagnosis that is often done badly.That and drivers often ignore the engine complaining and drive the nails in beyond return... 1 Quote Link to comment Share on other sites More sharing options...
