Tunatime Posted October 15, 2018 Share Posted October 15, 2018 Hi all have a problem with my discovery it's a 93 v8 3.5 efi. So the diff lock works makes a good clunk when I move left to right vice versa and light comes on on the dash but when I push the shifter fwd nothing engages I have looked underneath and all linkages are free and moving shaft to top of transfer case is moving in sync but no clunk or noise to indicate a solid engagement. Do I have a eternal transfer case problem? Any help would be appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 15, 2018 Share Posted October 15, 2018 When you push it forwards can you get drive? Do you move forwards in low range? Quote Link to comment Share on other sites More sharing options...
Tunatime Posted October 15, 2018 Author Share Posted October 15, 2018 Yup still get drive but seems to be going at the same speed as high box I will double check that this afternoon but it does have drive Quote Link to comment Share on other sites More sharing options...
Tunatime Posted October 15, 2018 Author Share Posted October 15, 2018 Also it's a auto trans Quote Link to comment Share on other sites More sharing options...
dave88sw Posted October 16, 2018 Share Posted October 16, 2018 On the top of the transfer box is a short rectangular housing held down with 6 bolts, the high/low selector arm enters through the end of the housing and a little finger pushes the selector inside the transfer box to shift ratios. If you remove that housing, inside is a grub screw that often comes loose, attaching the selector "finger" to the selector rod. The result of which is that everything looks like it is moving properly externally but nothing happens inside the transfer box when you go to shift. Quote Link to comment Share on other sites More sharing options...
paintman Posted October 16, 2018 Share Posted October 16, 2018 (edited) https://www.landyzone.co.uk/land-rover/how-do-i-disconnect-the-hi-lo-actuator-on-a-defender-200tdi-lt230.304097/ Post #5 shows the housing off & the view inside it. You can see the hole where the grub screw should be. They need to be put in with plenty of threadlock. Edited October 16, 2018 by paintman Quote Link to comment Share on other sites More sharing options...
Escape Posted October 17, 2018 Share Posted October 17, 2018 On 10/15/2018 at 8:45 PM, Tunatime said: Yup still get drive but seems to be going at the same speed as high box I will double check that this afternoon but it does have drive Have you tried taking it down the road up to some speed? With an autobox, it can seem deceptively fast crawling in low, but you'll notice it once the box shifts up. Not questioning you, but I've seen it happen, setting of with a heavy trailer, wondering why the box wouldn't shift to 3rd once on open road. In fact it was still in low (4th) from maneuvering... Quote Link to comment Share on other sites More sharing options...
Tunatime Posted October 17, 2018 Author Share Posted October 17, 2018 Have just taken the top of the transfer case off and yes the grub screw was completely gone will fish around with a magnet to try get it but I doubt that I will thanks for the help much appreciated. Quote Link to comment Share on other sites More sharing options...
