Hybrid_From_Hell Posted October 15, 2018 Share Posted October 15, 2018 Anyone know the differences between 90 v8 200 tdi 300 tdi and defendet td5 TCDi etc. Are they all the same "power" etc ..what's the differences between them or are they all pretty much the same ?? Quote Link to comment Share on other sites More sharing options...
Mutley Posted October 15, 2018 Share Posted October 15, 2018 Hybrid_From_Hell you really need to get out more! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 15, 2018 Author Share Posted October 15, 2018 At the moment it's like .... Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted October 16, 2018 Share Posted October 16, 2018 8 hours ago, Hybrid_From_Hell said: Anyone know the differences between 90 v8 200 tdi 300 tdi and defendet td5 TCDi etc. Are they all the same "power" etc ..what's the differences between them or are they all pretty much the same ?? https://en.wikipedia.org/wiki/Land_Rover_engines Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 16, 2018 Author Share Posted October 16, 2018 Er..how does that help exactly ??? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 16, 2018 Share Posted October 16, 2018 I suspect he presumed you were asking about the engines, rather than the master cylinders. As far as I'm aware it's pretty much the same master cylinder unit through the entirety of 90/110 Defender production. Some changes were made to the pedal box and the plumbing over the time. Tdci may be different as I've never taken one of those apart but certainly everything I've seen from the early 4cyl up to and including Td5 has been the same. Slave cylinders do vary, as you will know. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted October 16, 2018 Share Posted October 16, 2018 The masters are the same as far as I can make out - the only difference of any note is the switch body for the sensor that screws in to the outlet. 1 Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted October 18, 2018 Share Posted October 18, 2018 On 10/16/2018 at 1:22 PM, Retroanaconda said: I suspect he presumed you were asking about the engines, rather than the master cylinders. He did, apologies! Quote Link to comment Share on other sites More sharing options...
Daan Posted October 18, 2018 Share Posted October 18, 2018 Nigel, I don't know the answer to your question, but I do know that Trident racing supplies in Silverstone sells girling master cylinders which look identical to landrover ones, and have 3 different bore sizes. Could be worth a punt: Daan Quote Link to comment Share on other sites More sharing options...
