mmgemini Posted October 16, 2018 Share Posted October 16, 2018 Where, inside or out, fitted at rear ? ? Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted October 16, 2018 Share Posted October 16, 2018 You can get reverse light bulbs that also beep. Can't get much simpler to fit than that. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 16, 2018 Author Share Posted October 16, 2018 Yes I know you can but not LED Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 16, 2018 Share Posted October 16, 2018 Cough: https://www.amazon.co.uk/Back-Up-Reverse-Beeper-Universal-Automotive/dp/B078SQFH68 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 16, 2018 Author Share Posted October 16, 2018 Yes BUT They don't shine to the side. Somepeople want everything 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 16, 2018 Share Posted October 16, 2018 It has one of those domed lenses, I expect the beam is quite wide in reality, though I accept probably not as wide as a filament lamp. The lens on the lamp fitting may well help with it as well. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 16, 2018 Author Share Posted October 16, 2018 30 minutes ago, Bowie69 said: It has one of those domed lenses, I expect the beam is quite wide in reality, though I accept probably not as wide as a filament lamp. The lens on the lamp fitting may well help with it as well. Yes so it doesn't reflecy off the reflector in the Defender reverse light. I have those tower LEDs fitted which give a good light Quote Link to comment Share on other sites More sharing options...
western Posted October 16, 2018 Share Posted October 16, 2018 reverse alarm must switch off when the side/tail lights are on. IIRC it's covered by the same hours of use rules as the horn. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted October 16, 2018 Share Posted October 16, 2018 8 hours ago, mmgemini said: Where, inside or out, fitted at rear ? ? Or in the bin Unless you are on a construction site. Do you really need such a thing on a normal road car? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 17, 2018 Share Posted October 17, 2018 15 hours ago, mmgemini said: Yes so it doesn't reflecy off the reflector in the Defender reverse light. I have those tower LEDs fitted which give a good light Gotcha now, had in my mind's eye a fitting like: Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 17, 2018 Author Share Posted October 17, 2018 9 hours ago, Chicken Drumstick said: Or in the bin Unless you are on a construction site. Do you really need such a thing on a normal road car? Not where I live. I have to reverse nearly blind to get out Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 17, 2018 Author Share Posted October 17, 2018 No Bowie69 I have the oblong ones fitted 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 17, 2018 Share Posted October 17, 2018 Yeah, figured Quote Link to comment Share on other sites More sharing options...
