300tdi injector specs
oneandtwo
We have an all singing all dancing Hartridge testmaster2 computerised injector taste at work sat redundant that I was going to put to work testing the 30 plus 300tdi injectors I have spare.
I was going to programme it for 300tdi injectors but can’t find the crack off pressures and leak back specs online - anyone any ideas?
I hope this helps if you don't already know
- From the 1996 manual
Make & type - standard .................................................... Bosch KBAL 90 P37
Nozzle type ...................................................................... DSLA 145P366
Opening pressure (working pressure) .............................. Initial pressure 200 atmospheres, Secondary 280
atmospheres
from defendersource...
Also could you please verify that the pop-off for the 2.8 injector (0 432 193 532) is 201 bar while the 300 TDI (0 432 193 835) is 200 bar.
Thanks. It seems that although the tester is all singing, all dancing, it still requires a hideously expensive add on module for testing the second stage opening pressure.., still, at least I can measure the first stage, leakback and pattern then match up a set of them.
cheers!
  • 2 years later...
cheers!
Trying to do my own. How did you go on with a standard pop tester?
Mine isn’t really a standard pop tester - http://www.hartridge.com/products/testmaster-3-hh701/
I was actually thinking of testing another box load of 300tdi injectors shortly,
I did eight or so last year, a couple failed with really poor spray pattern, I stripped the injectors down and ultrasonically cleaned the parts and reassembled them, they then passed with good spray pattern and leak back figures, but without spending £1000 on the two stage add on I can only test them to the first opening.
super thanks. I've got new nozzles which are DTP replacement and meant to be very good ones so i will just test the opening as all i can do.
I wonder what difference the second stage makes and if being way out is really bad.....in case it was...
I have just removed and tested sixteen 300tdi injectors out of engines I removed from scrap discos some time ago. Out of these sixteen, only three were anything like reusable with good spray patterns and first stage crack off at between 194 and 197bar, and a long leakback duration. All the rest had poor spray patterns or were not cracking off correctly. I will strip a few and ultrasonically clean them and see if any can be resurrected at some point - new nozzles would sort out the majority.
I would think that a correct spray pattern and first stage pressure would be a good indication that the injector was reasonably good without having them tested on a two stage tester
They do have a two shim washers however they don’t appear to be adjustable with different shims - all the ones I stripped have identical washers.
Edited by oneandtwo
Thanks for that. That's is exactly what i needed to know. This type of info is marvellous indeed !
Based on info to come will determine what i need to do for sure. Testing the leak back is just a case of popping it and letting it sit. Is that correct. Let it sit and nothing drops?
That machine is set up for testing injectors from big Mirrlees Blackstone engines, those injectors have a crack off pressure and leak back duration provided by the manufacturer which is inputted into the tester. Once the machine registers the injector cracking off it then times how long it takes for the injector to drop to a certain pressure below the crack off and issues a pass / fail. I didn’t find leak back specs for 300tdi, so yes, let the injector sit and as long as the pressure slowly drops away over 15 -20 seconds it should be a healthy injector. Some of those I tested earlier today were dropping straight away to nothing.
  • 4 weeks later...
All injectors on the truck tested. All good. Slightly low pressure on all equally which is strange....old 4 from my box got new tips and 3 were resurrected from dribbling squirting rubbish to popping atomising magnificent status. Even correct pressure or there abouts. The last one was not working. Out of them all they are all shimmed and some had 2 shims in and some one shim all various thicknesses usually about 1mm. Some 1.5mm. I cannot figure out which shim size they are from the info online so cannot buy replacements. Any body have an idea? IIRC They are 2.8mm hole and 7 point something mm diameter. None of the ones online seem to be that size.
  • 2 weeks later...
  • 2 years later...
Hi I'vebeen pop testing my 100k plus miles injectors. some have good spray patern all popped at around 200p psi. l cleaned the nozzles with bad pattern, sprayed brake cleaner after and got good spray pattern, but on reassembly the spray pattern still poor? Any thoughts?
  • 1 month later...
Hi all
the shims are for adjusting the pop off pressure . The 200 Tdi has two,stage injectors. The 300 Tdi has single stage injectors as far as I know and have ready I could be wrong , I have never seen or heard of two stage injectors on a 300 . If you look at a 200 injector you can see the physical size difference between the two and the number 4 injector is different than the other three do to having a sensor telling the ECU the engine is warmed up.
the pop off pressure is 200 Bar which is 200x14.7(one atmosphere) = 2940PSI . If you can get them all to pop off at 2900 and have a really good spray pattern then you’re good to go .
When I do a full engine rebuild I order new injectors from Bosch if I can’t find new complete Injectors I’ll order new tips and build a set of matching injectors . I’ll then know they are going to list a long time trouble free. I’ll even order new internal springs . My engine builder has a tester and shims to adjust the injector to the right pop off pressure. . Not matter how long the injectors have been on your shelf you should test them to check on the spray pattern and pop off pressure .
the last set I had done my engine machine shop tested and adjusted them and installed a new set of injector tips that’s I provided . I know these are used injectors and I replace them with new ones but just on a complete rebuild . This way I know they are getting NEW injectors.
My question to everyone is does anyone know the injector tip number for the Bosch injectors used in the international 2.8 and where can I buy either the tips or the complete injectors for the 2.8.
I’ll buy new injectors if that’s all I can find but I have brand new injectors and I want to switch them to the 2.8 for more power .
if they are the same part number as the 300 then I’ll be golden lol.
I’m also looking for a part number and a place other than fourby to buy the boost pin and the boost ring kit to fit my 300 injection pump.
I can’t find the part numbers anywhere .
Fourby4x4 says they will sell me the injector tips for a 2.8 if I send mine over to the UK from Canada and they will install and test them . They won’t even give me the Bosch part number . I get it they have a shop to run . My problem is I live in Canada and the cost of shipping them back and forth across the other side of the pond is astronomical. They will also be returned to me if they are not super super clean . The diesel smell will set off the airport sensors lololol
if I send over my brand new injectors to have the tips installed how do I know I’ll get the brand new ones back and not used ones rebuilt .
 Any help would be great
thanks
Tony
My 200 and my 300 both have all four injectors on the respective engine identical to each other.  Some 300s have an EDC pump and might have a special injector associated with it, but not the plain hydro mechanical pumps.
200tdi injectors are the same on all cylinders. Some automatic 300tdi engines have an ECU controlled fuel injection pump that takes data from engine sensors including injector number 4, which is the same as the other injectors except it has a small sensor to let the ecu know it has just fired.  300tdi injectors are also 2 stage.
  • 2 weeks later...
12 hours ago, Little mule said:
Thanks eightpot.
is it really worth to the change to the 2.8 injector tips and use the 300 body, tube,and spring .
any improvements would be a plus
Tony
You should not change the injectors unless you are changing pistons to 2.8. The injectors sprav at an angle which is tailored to the swirl pot of the top of the piston. The 2.8 injectors have a smaller total hole diameter, so from a pure flow perspective, flow less fuel.
T
Hi Tobias
thanks for the advise is there any chance you might have the part numbers for the pistons , injectors, ?
if you had a parts book that would be even better. I know the 2.8 was in the ford rangers in Spain but no one seems to have a parts book for the truck . And in English lol
Tony
