qwakers 122 Posted November 7, 2018 nice but pricey Quote Share this post Link to post Share on other sites
FridgeFreezer 1,147 Posted November 7, 2018 Ignore the solar b*ll*cks, expensive controller is never going to pay for itself, £20 eBay MPPT jobby would do you just as well. Mind you, unless you're using a lot of electric the existing panel + any old controller should do fine. I see your fridge is gas so that's one big draw you don't have. Been through all this with the ambulance, there is so much bullsh... in the solar world it's unbelievable. Rule of thumb: your 100W panel will, on average, put 10W/hour into the battery over any given 24h period. Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 7, 2018 o you have a link to one you recommend ? Quote Share this post Link to post Share on other sites
FridgeFreezer 1,147 Posted November 8, 2018 This is the style I've used; if you're not wiring your loads through it you only need it rated to the panel's max output, so for your 100W panel a 10A one is plenty good enough unless you are friends with Elon Musk and he offers to launch the truck into the sun: https://www.ebay.co.uk/itm/163251911524 On the ambulance we have 2 of your panel and 2 of these controllers, but we burn more electric because the fridge is 12v-only and the 2nd battery is relatively small. Quote Share this post Link to post Share on other sites
Red90 133 Posted November 8, 2018 (edited) On 11/7/2018 at 6:49 AM, FridgeFreezer said: Ignore the solar b*ll*cks, expensive controller is never going to pay for itself,... Until the cheap price of carp cooks your battery or catches on fire and burns your truck to the ground. Edited November 8, 2018 by Red90 Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 8, 2018 7 hours ago, FridgeFreezer said: This is the style I've used; if you're not wiring your loads through it you only need it rated to the panel's max output, so for your 100W panel a 10A one is plenty good enough unless you are friends with Elon Musk and he offers to launch the truck into the sun: https://www.ebay.co.uk/itm/163251911524 On the ambulance we have 2 of your panel and 2 of these controllers, but we burn more electric because the fridge is 12v-only and the 2nd battery is relatively small. too high risk, most of them aren't mppt... ive already got a cheap pwm controller so if i upgrade i want to be sure what im getting... Quote Share this post Link to post Share on other sites
FridgeFreezer 1,147 Posted November 9, 2018 That guy in the video doesn't know the difference between PWM, MPPT, buck/boost regulation, and a hole in the ground... he also doesn't seem to understand the control schemes of any of the various controllers he tests. MPPT controllers still use PWM to regulate the charge, MPPT is just a smarter control scheme and that STM32 micro is more than up to having an MPPT control scheme in it. Anyway - I realise the cheap ones are cheap, but in response: That's why our setup has many fuses (in & out of both controllers) MPPT makes very little difference unless you absolutely must get every last bit of power out Many of the expensive ones are not provably any better (they wax lyrical about them in the marketing but are light on technical deets) I've had them apart and they're not horrifically badly made They've worked fine for some time now Given they're rated for 10/20/30A and your panel will never pass 5A, you've got a fair safety factor These ones at least show you some vaguely useful info for your £20, expensive ones tend to have a couple of blinky LED's and that's it. £20 doesn't buy you a dashboard battery gauge these days. If you weigh the difference between a £20 eBay one and a £200 CTEK, you might gain 10~20% performance with real MPPT (assuming the eBay one isn't MPPT) - for a 100W panel that's <24WH/day. If you really need that extra ~20%, spending some of the £180 difference on a bigger battery (or a pair of batteries) is going to be waaaay better value - every time you move, your alternator will dump way more juice back into the battery than your panel can manage, and with only lights, water pump and maybe a webasto to run even a small 100Ah battery will last days with a basic 100W panel + cheap controller topping it off. 3 Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 10, 2018 im never going to spend 200 on a controller 😂 and id disagree that hes clueless, he might have got two points materially wrong but the one point he makes is that it IS missing componants that it HAS TO HAVE to make it mppt, so at best its a pwm, and at that price, an expensive one. the result of which, im happy enough with the £8 pwm controller already fitted! if your setup works then great i was just mulling over the idea of changing to mppt, and have decided not to bother. Quote Share this post Link to post Share on other sites
FridgeFreezer 1,147 Posted November 12, 2018 No, he's wrong about exactly that - MPPT does not mean it would have ANY extra components, he's thinking of a buck/boost switch-mode power supply which is sweet-fa to do with MPPT. MPPT is a fairly simple algorithm where the controller moves the "balance" of load on the solar panel to achieve peak power transfer into the battery (like changing gears to keep the engine in its power band), which his video does precisely NOTHING to prove in any of the odd ways he goes about his "tests". The STM32 microprocessor fitted to the "cheap" unit is more than capable of doing MPPT stood on its head, and it would take longer to program the display routines into it than a basic MPPT routine. 2 Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 12, 2018 yes well lets not argue about that here Quote Share this post Link to post Share on other sites
FridgeFreezer 1,147 Posted November 12, 2018 1 1 Quote Share this post Link to post Share on other sites
bishbosh 20 Posted November 13, 2018 Oi Mr Fridge, that's my avatar you've pinched! Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 13, 2018 dso sunday i got a fair amount done on sunday replaced the solar panel, now charges fine. remains to be seen if the controller prevents it discharging at night. fitted the shower tray, the waste, and glued it down. just got the trim it out around the tray, fit the toilet and fit sink and shower head. trimmed the corners of the walls to clean up the carpet edges, used black plastic angle and superglue. looks good from here the old solar panel ocv was only 14v, the new one is 21v, so in low light levels it would pull down to 11v and thus discharge the batterys. the new panel doesnt, so all is well there. dont know weather thats a fault or just a carp panel. Quote Share this post Link to post Share on other sites
Blanco 80 Posted November 14, 2018 19 hours ago, bishbosh said: Oi Mr Fridge, that's my avatar you've pinched! To be fair though at least we can now share the joke, ....... it was limited to those with 40/20 vision before 1 Quote Share this post Link to post Share on other sites
geoffbeaumont 165 Posted November 14, 2018 On 11/13/2018 at 12:41 PM, bishbosh said: Oi Mr Fridge, that's my avatar you've pinched! To be fair, it went walkabouts from XKCD in the first place... Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 19, 2018 so the new solar panel and my cheap ass controller is working fine. even float mode has started working properly when battery is fully charged (panel voltage was never high enough to get there it seems with the old panel) and ive been refunded without any argument so they obviously know... ive also done a bit of preventative maintenance. ive cleaned off and waxoyled the bottom of the cab, both chassis rails and the underside of the floor.that should keep the rot at bay. none of the metalwork on the lorry is showing any serious corrosion, i just wanted to keep it that way. and 10l of waxoyl is a cheap way of doing that. last job yesterday was to sort the toilet/shower room out. first things first, why doesnt the bloody loo flush. i found the worlds best hidden glass fuse, it was blown, changed it still no go, checked the wiring and switches, no dice. onto the pump. ah there we go. new one of those on order, then i can put the unit back together and all will be well. trimmed up as much of the shower as i could. which just leaves me with finishing that off and bleaching all the old plastic. watch this space... literally Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 20, 2018 so the caravan gas guy came today to service the hob oven and fridge, now all working A-OK. bill was a bit steep but i got a full gas safety cert, 3 appliances jets cleaned and generally serviced and a new regulator and hose (reg i was using was too high pressure) for £150. not terrible i suppose and the fridge lights and cools! considering the state and age of it, im more than pleased with that! Quote Share this post Link to post Share on other sites
Arjan 186 Posted November 20, 2018 well done ! Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 21, 2018 (edited) changed the fan belt and coolant today. coolant was just pure water because id been fighting leaks (now all solved) fan belt... well see for yourself didn't get much else done, i was using my reciprocating saw to cut the doorframes flush, it snapped the blade. no biggie except... the chuck wont unlock. so that saw is now a expensive doorstop.. which kinda stopped me in my tracks. thats all, folks! Edited November 21, 2018 by qwakers Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 25, 2018 today involved some welding, with a inadequate power supply, so that was always going to be a issue. (unhappy welder RHS light, thermal protect mode) to get decent penetration i ended up having to preheat with oxy-propane. (not with the crappy gas torch you see in the pic.) so ramp hinges made, and plummer blocks fitted, just have to get some stainless solid bar to go in them and job done. toilet area nearly done, just gotta fit the shower part and thatll be done cupboards/storage unit given a haircut (split in to two towers rather than three) and attached to the wall almost there 1 Quote Share this post Link to post Share on other sites
discomikey 91 Posted November 25, 2018 following! what type of racing will you be supporting with it? Looking good! our setup is a BT back on an Iveco van with a trailer, good, but somewhat lacking in space, and creature comforts! Quote Share this post Link to post Share on other sites
qwakers 122 Posted November 25, 2018 i hillclimb and sprint, club level. it will also be great for trackdays and events like japfest and JDM. i cant do the car and trailer thing otherwise i would, but my licence doesn't allow. plus, buying a medium sized motor-home and a covered(OR not but lets leave it comparable here) trailer even second hand is going to be north of £20k! this is cheaper, easier and more convenient. only downside is parking it, fuel economy (not that bad really) and having to use my tacho card, which means if i ever get back into driving for a living ill have to get rid. Quote Share this post Link to post Share on other sites
discomikey 91 Posted November 28, 2018 On 11/25/2018 at 9:14 PM, qwakers said: i hillclimb and sprint, club level. it will also be great for trackdays and events like japfest and JDM. i cant do the car and trailer thing otherwise i would, but my licence doesn't allow. plus, buying a medium sized motor-home and a covered(OR not but lets leave it comparable here) trailer even second hand is going to be north of £20k! this is cheaper, easier and more convenient. only downside is parking it, fuel economy (not that bad really) and having to use my tacho card, which means if i ever get back into driving for a living ill have to get rid. I assume you have a C license then? A few of the ultra4 boys we run with take a rigid wagon. It seems handy, and our 6x6 Tatra service truck at work does the trick nicely. Even that can get a little small though when there's 4+ of you working on as many cars! Quote Share this post Link to post Share on other sites
Arjan 186 Posted November 28, 2018 Looking good. We have the Iveco for the horses and looking for a C cat 4x4 truck for longer trips Quote Share this post Link to post Share on other sites
