Sign in to follow this
mat2495
200tdi timing marks incorrect?
Evening all, I think i may have a problem setting  up the injector pump timing on my 200tdi. Apologies in advance for the wall of text
The backstory: this is a completely rebuilt engine for a 110 I am restoring, reground crank, bores honed, new rings, bearings, 2x new rods, new turbo etc etc. Obviously a new timing belt, tensioner etc as well. Before I removed the injector pump from the engine, it was locked in the TDC position, and was put back in the same place, the cam/crank were then aligned with the timing marks and a new belt fitted as per manual. When I eventually came to start it, it was pretty reluctant to go, and when it did catch it was throwing out loads of white/grey smoke. it also wouldn't pick up any revs cleanly, just bogged down. To me this suggested that the timing was retarded, as the smoke smelled very diesel-y, but I rechecked using the slot on the flywheel and the pin in the pump, which checked out okay. I did wonder about a leaking injector, as the engine had been stood for some time, so I swapped them out with the ones from my other engine (a good runner) but it did not make any noticeable difference. Today I decided to go back to my first thought, so I advanced the timing as far as the slots in the injector pump pulley locking plate would allow, and it was much better, started nearly instantly, quite a clean idle, and just a little smoke when prodding the throttle.
So onto the question, is there any way the key in the front of the injector pump could become disassociated with the actual correct timing point of the pump? I did not remove the drive flange from the pump at any time, as I don't think the 200 pump has a keyway on it. I guess a sensible next step is to set up the pump timing with a DTI, is there a kit available with the necessary adapters? Also as I have maxed out the travel on the adjustment available, I suppose I will have to strip the timing cover off again, which I didn't really want to do. Alternatively can anyone think of anything else that could cause symptoms like these? Is there anything internal to the pump that can affect the injection timing?
Matt
Share this post
Link to post
if you haven't moved the pulley or drive boss from the FIP shaft & slackened off the 3 bolts during tensionning of the belt it should be fine once all set & tightened up.
Share this post
Link to post
Is it possible there is some degree of option in where the flywheel mounts on the crank, as that relationship also come into play? You must have had that apart to regrind the crank. Apart from that it does sound like you may not have the belt quite right. The timing kits are available with and without DTI on ebay, and  doubtless elsewhere, and there are videos of it on youtube.
Share this post
Link to post
19J shown below, I'm sure the 200Tdi will be the same. There is a locating dowel on the crank for the flywheel so you can only put it on in one position. The fact that when the pump sprocket was moved resulted in an improvement suggests to me that the pump timing is not quite right.
Share this post
Link to post
Yes there is a location dowel on a 200tdi crank, it's the same crankshaft in both engines,
 this is mine during the rebuild
Share this post
Link to post
fourby 4x4 do a dti kit for the pump.
speak to neil he will sort you out
Share this post
Link to post
Thanks Tim, I will give them a call.
I agree it should be right, and as you say the flywheel is doweled onto the crank.
Is it possible that the boss on the front of the FIP has slipped slightly at some point? I know its tight on a taper, but I have reason to believe the engine came to a very sudden stop before I bought it, could it have slipped then? Its looking at something like 10 degrees out of line, maybe more
Share this post
Link to post
The pump shafts do not have a key.  The flange is installed and set by the pump builder in order to get the timing correct..  It could be off.  Use a dial gauge to set the timing.  It is a much better method and you know it will be right.
Share this post
Link to post
Righto, time for an update! I got a DTI kit, and set the FIP to 1.54mm of lift at TDC ( I also checked that no 1 was at TDC when the timing mark on the flywheel said it was) and it is actually worse.. 1.54mm of lift is actually less advance than I had tried previously by simply maxing out the advance adjustment.
Long story short, unless the pump has got something else wrong with it internally, it doesn't appear to be the problem. Anyone got any other ideas for what could cause clouds of white-ish smoke and the inability to rev?
Share this post
Link to post
How exactly are you verifying TDC?
My best guess at this point is cam belt is installed wrong with the cam out a tooth or two.
Share this post
Link to post
Probably unrelated, but I will throw it out there.
I think I had a similar issue with an old ford transit diesel engine retrofit many years ago.
IIRC it was caused by having the wrong banjo fitting in the Fuel return line. The incorrect banjo had a very small hole internally and was restricting the flow to return.
Share this post
Link to post
Some flywheels have two notches which can create your problem if you're timing from the wrong one.
Share this post
Link to post
TDC verified with a probe down the glowplug hole, which agrees with the timing mark on the crank pulley, and the slot in the flywheel. I'm beginning to wonder about the cam timing as well, I don't suppose there is any way to check it without removing the front cover is there? I know when they are supposed to open and shut is in the workshop manual, but i'm not sure I can reasonably measure that many degrees before/after TDC with any real accuracy. Ah well, timing cover off again it is! Nevermind eh
Thanks for the thought, but I would hope this isn't the case as I have re-used the original fittings from this engine.
Share this post
Link to post
Yep whip it all off and check again, for the sake of a couple of gaskets and an hours slandering.
Do double check to see if you have two flywheel slots first though - they are only a few degrees apart, but chances are the belt just needs refitting.
Share this post
Link to post
200tdi flywheel TDC use the NARROW lot, the other much wider slot is for the older TD engine. there is a photo in Defender forum somewhere that I added to a post a while ago.
Share this post
Link to post
'Slandering' wtf?? 🤨  bloomin autocorrect 😆
Share this post
Link to post
I'm with the other chaps Matt, timing cover off and start from scratch.
HTH
Mo
Share this post
Link to post
Sounds like my weekend plans are sorted then! Be a bit embarrassing when it turns out I missed by a couple of teeth! I was so careful as well as I have never done a 200tdi belt before.
I don't know, I'll probably be slandering a couple of the design decisions before I've finished!
The correct one is about 4-5mm I think? I know what you mean though, the other one is much wider.
Thanks all
Share this post
Link to post
You can run the engine briefly with the front cover off to test before you reassemble everything (make sure you take the timing pin back out!)
Share this post
Link to post
Oh good, that's worth knowing, I wasn't brave enough to try that last time, thought the fact that it was still on and engine stand probably didn't help!
Share this post
Link to post
Well, good news and bad news! the good news is I did get the timing belt set up correctly, the bad news is I still don't know what is wrong.
Is there a mechanism in the injector pump to adjust the advance for increasing engine speeds? I'm just thinking if it is timed correctly statically, it would then be retarded at 700RPM, and even further retarded at 1200RPM etc. which would explain why advancing it past 'correct' improved the idle, but it still wouldn't pick up any rev's cleanly.
I think it may be time to take the injector pump of and send it away for testing
Share this post
Link to post
If the pump was working ok before, and you're confident you have set the crank/cam/pump correctly when installing the timing belt, I would be starting to wonder if the problem lies elsewhere.  Have you Got a compression tester?
It's not unheard of to have a bit of something find it's way under the head gasket or some water/oil in the head bolt holes stopping the head clamping down properly for example.  Personally, I would be investigating that first before spending on a recon fip.
Share this post
Link to post
Did you have the 3 small hex bolts slackened while setting the timing, as the manual instructs.
Share this post
Link to post
The pump was working okay when the engine was laid up, which I believe was circa 5-10 years ago. And I use the term laid up loosely.. suffice to say it wasn't in the best condition when I got it
Compression checks out, no more than 20PSI difference between cylinders, and that was with the battery starting to go towards the end. All around the 370-400 PSI mark
Yes, to be sure I re-printed the manual and followed it to the letter.
  • Like 1
Share this post
Link to post
Let's see a picture of the timing marks.  It is not that uncommon for people to do it wrong as the instructions are a bit confusing.  You need to step back and take a fresh look or have someone take a fresh look.  It is most likely that you have done something wrong and can't see the forest for the trees.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
